- Fuel filter...
- Battery removal w/o resetting security codes?
- Fuel pump not priming - click under hood/dash
- rebuilding VQ, FI or NA
- Planning my build, could use some expert advice
- Expansion Hose Leak
- Rev Motor twin intake versus single
- MR Y Pipe questions
- RPM increase when clutch depress normal?
- common shifting "problem"
- Need Help.....Mixed Transmission fluid.
- Differential Gear Info
- k&n billet reusable oil filter?
- G35 2004 coupe Engine Harness question please help
- G35X 2007 Starter Removal
- G35 riddled with small, annoying problems?
- Jim Wolf C8 cams and NVSC
- r&d factory valve covers?
- Pinging/Knocking 2005 G35 Sedan
- Same problem - new day - AT Controller Fuse?
- Cams to make 300awhp???
- Installing Right Door Actuator, how to?
- 2003 G35 Sedan Making a rattling noise at around 1500 rpms
- rod knock, help. 1/27/13
- Vq35de (neo) ?
- New Build wont start - need some help
- Clutch Recommendations
- Overheating after Valve Cover gasket change?
- oil consumption, new motor out of warranty?
- automatic transmission help?
- Car in the Shop for 5 months
- Lower Oil Pan Question
- Motordyne Plenum Install Rough Idle
- no smoke oil consumption
- Chipping a 2003 Sedan
- No one has been able to resolve, please help.
- P0507 Code but I have a normal idle
- interchangeble engines
- Every ECU Pinout is wrong for my car. Help me wire my piggyback!
- Spark Plugs
- Oil consumption. Overall concensus??
- Idler A/C pulley assembling woes...06 G35
- Weird Noise on G35 coupe
- Radiator cap reviews
- Loosing coolant...
- 5AT nonrevup G mods
- Stalling after warm start-ups after fuel level sensor cleaning
- I am getting code P0304 which is a Cylinder 4 Misfire on my 2005 G35 Sedan HELP!
- Engine room harness plugs - wire tuck and ID needed
- Just starting out!
- P-300 Misfire Issue
- car wont start upper plenum
- exedy clutch
- Tuning Questions
- Heater issue in 2006 g35x
- Annoying Noise when A/C is on - Help
- 06 Rev-Up Sputtering Under WOT. Code is "Multiple Cylinder Misfire" What's the cause?
- Engine Whine - In neutral or in gear, but goes away when clutch depressed
- Rear subframe Differential Bushing NorCal
- HKS Beginners Guide to Tuning
- adjusting tension on drive belts now car wont start??
- Need Fuel Pump Rubber Grommet Please Help - Cant Locate Anywhere; Stage 4 Stillen
- Motor Dies after cold start (unlessed rev'd)
- New JDM HKS ST Build but what are these parts ?
- Found Oil In coolant when i replaced radiator
- Nissan 5.6 litre swap
- JDM Oil Consumption and Warranty Company Screwing me over
- That engine rattle ]:
- engine making clicking sound
- how much hp can the stock heads/cams handle?
- Transmission question
- G35X buzzing rattle from engine area
- Changed Radiator Now Temp Gauge going Up/Down as Rpms Increase
- G35 03 coupe HKS single exhaust video! (short rev clip)
- Pulley bearings going bad??
- Cosworth oil pump... worth it?
- Burning oil
- What upgrades work well?
- Turbonetics Kit Upgrade Help
- Known Oil leak into cylinder
- 03 G35 Nitrous Window Switch Install
- new engine due to oil consumtpion but dissapointments.
- oem clutch/jwt flywheel to act hdss/jwt and its easier???
- Stock pressure plate with ceramic 6 puck ok??
- Springs Vs. Coil Overs
- Performance Chip
- engine help
- Thump when starting engine after sitting
- Rubbing/grinding Noise after Clutch and Flywheel install ('05 G35)
- CAN communication code help after fan install
- Removed my resonator, No BS it helps!
- 2003 Overheating when driving (Any speed)
- Codes p0303 and p0340
- P0345 Engine Problem: VTC Sprocket or Pulley
- O/C showing at 89k miles, options?
- 2008 g35x pumpkin in a 350z
- Oil light
- Mishimoto Power Steering / Coolant
- Engine Oil.
- Need help with engine swapping 05 G sedan
