PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
  1. Maf sensor placement
  2. Making Oil Changes Easier
  3. Planning to buy a long tube headers for my sedan which your recommend
  4. 6MT Take Off Issue
  5. OEM Throwout Bearing
  6. Replacing my engine looking for other mods to do
  7. power adders
  8. Dipstick reads half full at 1200 miles
  9. 2003 g35 running rough- HELP
  10. NEW!!! SOHO Motorsports Single Turbo Kit!
  11. piston questions.
  12. A lil help on Overheating
  13. Motul Nismo Engine Oil
  14. Aftermarket Dry Panel Filters...
  15. Nissan Z/G VDC & Yaw Sensor vs ECU Tuning
  16. Accidentally engaged a rev limiter at 2200 RPM?
  17. Clicking Noise
  18. New Engine: Now low on coolant and power steering!
  19. CEL code on 06 6mt
  20. Clutch went flat?
  21. throw out bearing
  22. carbon fiber hood ?
  23. New Starter Issues
  24. spark plug boot puller
  25. Headers and test pipe advice.
  26. Best aftermarket clutch?
  27. please help me identify this noise
  28. Need help with vdc issue?
  29. Low-end torque
  30. Is this normal 5AT operation?
  31. Air in Coolant
  32. Clutch pedal sticking?
  33. Shifting to 2nd gear chokes....
  34. Replacing Clutch Cost?
  35. Speed limiter??
  36. 5w40 RP
  37. JWT 700bb kit question
  38. Qualified: NEW ENGINE!
  39. Borla, Magnaflow, Nismo, HKS?
  40. V35 parts - Help pls
  41. weird idle and loss of power please help
  42. Build or replace???
  43. exhaust is acting up
  44. Makeshift Catch Can Install & Throttle Body Coolant Delete - Now 900rpm Idle
  45. JWT clutch/Competition flywheel help
  46. uprev for hp tq over 600??
  47. Can I just Matic-S for PS fluid?
  48. Lifespan of the VQ35DE?
  49. Good read for NA VQ builders
  50. First Automatic Transmission Fluid Change at 90k
  51. White smoke and fuel smell from exhaust
  52. Car Battery Randomly Dies
  53. screeching as i accelerate!?
  54. Leak Down and Compression Results - Info?
  55. [Help] cd009 installation in 03 coupe
  56. Engine change in driveway
  57. How to change the thermostat on a 2003 G35 coupe
  58. Bank 1 variable timing issue, P0011
  59. Engine temp!
  60. '06 Sedan won't idle
  61. SxExCx: Now offering TransGo install...AMAZING deal!
  62. The FIRST aftermarket VQ transmission pan
  63. 2004.5 Wideband o2 Sensor and P1283 code.
  64. Installing stillen oil pan with gasket and not RTV
  65. wet weather/rain stall - hesitation - P0102 P0506
  66. Pulleys and best kit?
  67. Getting tired of the one thing after another!!!! Now a cracked greddy manifold !!!!
  68. Camshaft position sensor connector
  69. Valve Lifter issues (cam followers)
  70. vq35DE and vq35HR in depth comparison
  71. Valve Cover Gaskets - Ad Nauseum
  72. New Megan V2 tp's $100 go for it?
  73. Sound coming from Car
  74. Help -auto to manual- not starting
  75. Haltech Dual or Single 02 Sensors
  76. Hoping for feedback for any boosted who swapped 3.5 rear end to 3.3
  77. are most HKS replica's the same?
  78. Knock Sensor HELP
  79. Help identify this harness!!
  80. A little advise please
  81. Damaged hose, maybe radiator or AC, should i drive or tow?
  82. My vq35de blew. Can i swap it with the vq35hr motor?
  83. starting issues
  84. Is it a good idea to sleeve your vqde heard a lot of bad stories
  85. Power steering pump cleaning
  86. Plenum + clean throttle = troubles
  87. change radiator fluid?
  88. Upgrading fuel pump?
  89. TT Repair Shop in Philly Area
  90. TT Repair Shop in Philly Area
  91. Oil consumption mystery
  92. 03 G35 coupe white smoke passenger side engine
  93. Vegas Heat = Need options for better cooling !!
  94. Engine Seized...Infiniti/warranty???
  95. No code, exhaust smells lean
  96. Oil consumption tsb with mods?
  97. Supertine/AC Belt Squeal
  98. P0011 cel/mil?
  99. ticking from engine?
  100. Engine Stuttering
