- Valve cover and seals help
- HELP.. car died and wont start!!!
- Rev too high?
- No power from launch
- waterpump @ 77k?
- Check engine light on 04' X, what's my worst-case?
- Help, car won't start!!! Bad cam/crank sensor? Please help me diagnose
- Ticking sound at 75-80 MPH and 3k RPMS.
- Getting to my last power mods... Stillen Engine Damper/AMS Pulleys
- What oil is recommended for G35?
- G35 Coupe squeaky pulley when hot... not cold
- Nitrous 150 Shot build
- HR..Question
- air is not bleeding. need help ASAP
- Probs with Greddy 18g TT setup???
- Transmission Revision?
- valve guide seals
- Valve Cover Gaskets
- Oil in spark plugs wells, both sides
- Under Drive Pulley Set??
- Anyone changed out their distributor cap/rotor?
- HELP...Please.....Rough start up this morning
- Replacing one tire on G35 w/ AWD transmission bad idea?
- Lots of Codes after putting new Engine in
- Advice for Fellow G35 Owner
- Spark Plugs (Bosch cheap on rockauto)
- "Sweet" smell from rear of G coupe
- New Engine Harness Connectors...
- engine hard starts/ stutter
- Blown Headgasket opinions please!
- DIY engine removal?
- piston rings?
- Prepping for a Engine Swap: Any Advice:
- picked up stage 4 stillen supercharger! Now got ??
- Problem with parts Selection for my 2004 G35x
- P0037;P0159; Stillen HFCs
- HKS Ignition Booster Install - Misfiring and Lean
- Water pump cover metal tab
- Chirp/Cricket noise while accelerating at high gear low speed (6th Gear @ 20-30 MPH)
- Meth/Water Inj - How/where to mount nozzle
- Radiator fluid leak
- My 0-60 Times...Is this Normal?
- Whoosh sound immediately after shifting - 5AT
- Rattling Noise from Inside the Car
- New!!
- Exaust smoke
- code p1283
- Chattering Car
- Why can I not solder the timing cover?
- evap canister stock location help picture?
- crankshaft cracked...
- Help! pretty sure 5/16 plastic bolt spacer went into engine.
- Need some advice for my NA build
- My new build .. your recommendations
- NEW!!! SxExCx Custom Tank Set V3 (Round)
- Changed alternator, now car won't start
- engine wont start, help please
- LS Swap Sikky vs Hinson
- My car starts up but i have no acceleration??
- SxExCx Grounding Kit for Manual Tranny Review
- Part Numbers, Where do you Find Them?
- Need after market end links, any suggestion?
- service engine light - timer??
- Fitting Procharger in a V35 Right hand drive skyline
- Infiniti XYZ Pipe with HFC + ART Pipe Combo
- aftermarket wideband gauge for use with oem wideband
- nitrous 50 shot
- Getting Ready for a Tune- Anything Else?
- Coupe vs Sedan - engine harness question
- VQ35DE Cylinder Block Numbers/Revisions
- grinding gears
- Ac/Heater fan problem??? help plz
- Debating on a possible next mod
- primary timing chain alignment question
- Oil Pump
- Help!
- DIY - Starter Replacement
- Fog Lamp Bulb Size???
- Thanksgiving week! - check out the huge deals!
- what you guys thought about this?
- Best Bang for the Buck Mods (Please help)
- Need help!....possible belt issue?
- could hear coolant circulating
- Alternator G35 same as all others?
- How would one fix oil in the spark plug issue
- Blowing out carbon deposits
- Turbo Kit spark plugs
- VDC OFF and SLIP lights when cold/rainy
- Clutch Chatter...
- Noise before gear change from 1st to 2nd
- AT Upgrade Rating Thread?
- Cam sensors
- Strange smell in the cab when the car is floored....
- Once you used synthetic engine oil, you should always stick to it?
- ECU Reset......THE EASY WAY!!!
- Grounding kits
- g35 coupe differential fluid? mobil 1 75w90?
- few issues
- Problems!!! Misfire, shaking
- No compression in cylinder 4!!!
