- Oil Drain Plug
- Dex-Coolant Concern....
- Urgent help please! Engine turns about 3/4 turn, stops.
- Replace G35x engine with a G35?
- VQ35DE Engine Bay Bolt Sizes
- G35 coupe gear shift ? question
- Motor Oil Viscosity/Weight Recommendation...
- P1273 and P1283 Codes
- What are my odds of oil consumption problems?
- Blown Headgasket???
- Low end torque improvement recommendations
- Running Lean or Rich??
- Fans
- AAM Angled Plenum Spacer
- What engine to put back in
- 2 quick questions re engine bay mods
- weird overheating issue* ideas ? help?
- Sea Foam...
- Crunchy Clutch or crunch shifter???
- Stupid Gas Tank Issue
- Fuel Help Please...
- Final Drive Ratio for a 2006 Sport Coupe with VLSD
- 4.3l vq35dett
- sputters no/power
- after changing water pump and gasket due overheat help plz
- are you happy with your stillen crank pulley?
- Next mod?
- How do I improve the shifts in an automatic g35?
- Are 14935-AM60B and 14935-JF00B interchangeable?
- what is the best oil for vq35de?
- Help,,car wont start! :/ 2005 G35 coupe
- Clutch Problem - Yes I've Searched
- Where's the starter located?!
- Fail: power steering
- Nissan Matic J , D , S ???
- Add hp - 2003 6mt coupe
- Need a clutch help please
- Coil packs
- Help identify this part!
- knocking noise in engine
- thoughts on Mishimoto hoses
- Anyone ever wrap their own engine bay hoses??
- continued revs after clutch pushed in.. yikes!
- Trip odometer/gas gauge
- Default Momentum Performance Super Sale (FREE EXHAUST)
- Help with gaskets and O-rings questions
- anyone with pauter rods...crank balancing issue?
- Something Worth Trying??
- Emission Problem/ High RPMs ???????
- 125,000 miles things?
- overheating - not the usual suspects
- pennzoil ultra
- Interesting engine noise?
- Alternator belt part number???
- Engine stall at idle
- New to this forum-- help
- Mis-fire on cylinder. At a loss.
- how can i improve my shifting and timing
- Stillen X-Pipe Doesn't Line Up With Cats
- Possible busted engine mounts?
- Throttle body spacer
- rough/low idle after camshaft sensor install
- Non-revup block and Revup block compatible?
- HELP, i think my engine has knocking?
- Hydrolock recovery help
- Engine replacement help please
- Attempting to Build a Differential
- K&N Cold Air Intakes do not work in G35s...
- HELPP please! quick stutter, service engine light , then gone
- Stillen intake problem
- 03 stalling/jerking and overheating
- catch can?
- replace oem hoses
- D-Wolf clutch kit mod??
- whats next??
- OBX underdrive crank pulley
- Spill Proof Funnel & Mishimoto Raidator - HELP!
- G35 Crankshaft! VQ35DE VS. VQ35HR
- weird sound and horrible exhaust smell
- Turbonetics any good??
- Where else can I get turbo kits besides z1??
- Vacuum Line
- Ignition Coils burning out!!!
- G35 Greddy TT Project Questions
- Engine Start Up High Revs
- HELP!!! P2A03 code!
- STILLEN Obtains 50-State Legal Status For 370Z/G37 Supercharger
- Cooling fan motor question!
- new clutch problem
- cooling & heating help
- Transmission flush problems, won't flush
- I went to Midas the other day...
- Greddy TT Fuel Pump???
- OC Stock block rebuild question? Help needed.
- is this normal?
- After installation of Transgo, engine won't start
- Z1 Motorsports presents the 2011 Z Nationals
- Clutch Cooler?
- LSx 383 Stroker 6.3l
- 6 speed swap, U1000 code, popping fuse
