- Irene vs g35
- New Owner Daily Driver Setup
- Please help me, i'm on a budget as well...Exedy Clutch, need flywheel or no?
- Cleaned injectors @ 128k miles
- Popping noise need help
- Engine running too lean!
- CEL and limp mode...
- Aluminium valve covers installed w/ 22448-4W011 coil packs
- Fan shroud
- Need help with check engine light or have a question about an engine codes?
- OverHeat Boiling Airlock.....Vaccum Airlift?
- rpm revs on it's own after I cleaned TB
- Can i swap out my VQ35DE for a QR25DE?
- dumb dumb dumb.... :(
- DIY: How to wire Forged Racing Aluminum Fan Shroud
- Alternator Replacement Question
- Sucessful Throttle Body/Failed Cam Pos Sensor experience...
- G35 vs G35x motor
- Clutch help
- Coolant leak. Need advice
- Advice on Engine mods
- Frying coil packs.... Help
- Want to change my spark plugs, need advice regarding the oil leak
- Speedbump killed the cat! Please Help!
- A little help please............Car competely dead as if no battery
- oxygen senor question
- Couple of codes on a 04 coupe
- Intake/Spacer Setup Question
- Slip & vdc off llights on ???
- Oil Consumption I have it, What should I do???
- Are these codes related??
- Engine Cranks over but won't start?
- Service Engine Light...
- G35 sedan ECU interchangeability
- APP sensor/no throttle response
- Installed Motordyne 5/16 spacer, thermal aramid gasket, copper throttle body heater
- Clutch engaging point aways very low?
- Clutch master cylinder upgrade? Help please!
- P001 & P0011 Please Help!
- Best OEM Radiator replacement ?
- wet exhaust tips after oil change
- Reputable Mods For Good Gains?
- how to shut off dash lights?
- Remove Cat For Downpipe ?
- Help needed
- Car Died ?
- Lift rattle?
- @ Mechanics, Serious Help Needed, G35 Coupe Problems!
- Couple valve lapping questions. Calling all engine builders!!!
- VQ35DE Rev-Up Cams
- Larger idler/tension pulley?
- Performance Suggestions???
- unknown engine noise. Lifter?
- Throttle Response delay?? (vid included)
- Stock size lighten pulleys?????
- Overheating issues---PLEASE HELP
- 2003-2004 G35 Overheating Sticky Worthy
- need help
- forced induction part giveaway
- Royal Purple?
- Car issues: Possibly tranny
- cabin air filter question
- 2006 WRX better clutch than my 2003 sedan 6MT?
- what O2 sensor to buy
- "Hissing" noise from HFC - sounds like something loose inside
- Supercharged G35 faster than G37?
- A friendly FYI
- Just bought a 2004 infiniti g35 coupe
- Idler Pulley How to replace.
- Please help! car is bogging!!!!
- Need help asap :(
- turn off rev flasher
- oil cooler and/or high capacity pan
- car problem can anyone help
- need a mechanic's advice - valve cover issues
- Any one know the part number for O rings that R n D factory sell????
- LQ4 swap questions--help please
- cam sensor code
- Ideas for removing stripped coolant bleeder screw? (Pic)
- Mod+Tune = Burning oil?????
- Who makes JWT clutch & flywheel?
- High Idle
- 6MT Hard Going into 2nd Gear
- Does your transmission rattle?
- PLEASE help... Throttle, engine codes..
- Oil cooler for n/a
- Engine Knock/Ticking when parked?
- Opinion on Possibly damaged engine
- Engine ticking/clicking and need your help. youtube video included.
- Another engine noise video diagnositic, help!
- Overheating issue--help please
- gas
- Should I rebuild my engine?
- Compression test
- Oem plugs gap'd at .040???
- My car Turns off
- Help with mistake, Put water in tank
- Radiators
- Feels like Gas pedal not working?
- Best Spark plugs for a tune
