- Motor Swap!
- How to install AAM fuel return kit? Help please
- Transmission issues
- Loud clicking
- Starting problems with remote starter
- Air in the clutch??? HELP ME PLZZZZ!
- Passenger Valve Cover Clearance Issues
- Changed out spark plugs now car wont run, help
- Please diagnose engine noise, maybe injector or fuel damper. Video inside
- Misfire in cylinder 1
- HAND BRAKE LIGHT and BATTERY light ON!
- Replaced Spark Plugs and idling drops
- compressor problems.
- Raising Idle, Changing Vortech Bypass Valve
- Valve Cover Q (need help)
- Mizu Radiator Install
- ac belt tensioner pulley bolt size
- Cooling Fan
- rpm bounces on high rpm
- 02 v35 skyline 250gt
- 2JZ Swap
- Zeitronix Zt-2 Install Plus Utec EMS
- Engine block replaced at 50k, now 100k oil consumption issue again?!?!?!
- Will this do it?
- Replacing the spark plug well seals in the valve covers
- Loud tapping sound when the car is cold
- low speed rpm surge
- Vibration in car after boosting supercharged G
- new parts ces lights still on
- Clutch Replacement
- My car sounds like a boat?!!
- swap possibilities
- VQ N/A build
- cam sensor pop out
- idle issue
- fan questions
- Vq35hr manual swap into g35 automatic with vq35de ?
- hurt cam. lifter or both
- Info on engine swap PLEASE!!!
- Click/clunk underneath in 1st gear
- Engine Rebuilt advice for Heads on Revup
- g35 stutturing
- Tranny issue!
- Engine ticking noise
- High Performace Cams, a good option for our cars?
- Anyone had there G motor ported and polished???
- HELP! Wont pass smog!
- just bought Used G35, need maint advice!
- Pep Boys velocity stack
- Check timing chain w/o remove the cover ?
- 2.5'' or 3'' exhaust?
- 03 coupe upgrades
- Stumbling as soon as the car is started, exhaust smoke, tach needle
- My G is leaking oil.. From everywhere
- best way to increase 91 octane to 93?????
- ... WAIT A MINUTE... or maybe...?
- strange noise, help if you can
- New Owner! 04 6MT question!!
- Help spark plugs question
- finally saved money to mod my G
- Car Smoking.
- ECM 2004 coupe g35
- Another ticking ?
- !! Stripped Cat Bolt !!
- 06 Coupe 6MT - Clutch and Flywheel are going out
- Forged bottom end---help please
- Engine Knocking and Serpentine Belts
- Fuel Pressure Regulator gone bad?
- Fuel Filter
- will a sedan engine work in 03 coupe?
- Engine feels weak
- O2 sensor replacement
- o ring between maf sensor and tube?
- Help? Mobil 1 Synthetic ATF Multi-Vehicle Formula as PS fluid?
- engine maintenance
- car keeps backfiring! need help :(
- who has a NRG ps tank
- burning coolant
- Need Tech Help With Small Upgrade
- Revup Plenum on a Non-Revup Engine??
- HELP! after cleaning throttle body and maf sensor= rpms are jumping!
- HELP!! p0021 and p0300 codes on 03 G35-sedan
- people that have done wiretucks themself
- plenum spacer trouble
- Modification advice needed
- people with supa fresh dope skittle engine bays
- FCON Gurus on here?
- oil cooler setups?
- Do all G37's have 3.7FD?
- x02 exhaust
- I might not pass smog?
- AMS Lightweight Pulleys... final word? and JWT cams... help??
- What additional mods will give me decent power inc.? already searched...
- 03 4dr doesnt pass 40mph then revs up..help..
- Works Bell paddle shifter
- what is this?
- Engine squeal under hard(er) accelerating
- Borla
- Clutch pedal question
- Help finding size and nice hose clamps!! Plz
