- Check Engine Light on...got the code P0420, what should I look for?
- 100% synthetic oil filter for G35 engines [VIDEO]
- single or twin turbo
- Need help with Vortech V3 install
- synthetic the only way to go?
- Can i fit 07' coupe Transmission on 03 G coupe
- G35 ticking noise? help and suggestions?
- Act Clutch
- Whining noise after plenum spacer Installation... PLEASE HELP
- Does this have a spacer?
- Timing Belt and Brake
- Kinetix V+ plunum
- batt light on,steering failure??
- FAN CLUTCH Facts / Myths ONCE AND FOR ALL
- Nismo roller pilot bearing issue
- What to look for or check when buying an 03 Coupe M6 180000kms?
- Can I change my clutch fluid this way???
- V35 General Maintenance
- Weak coil or possible misfire...
- plugs
- Variable catch can setups
- coolant fluid questions
- Engine Starting Trouble! Batter, Starter or Alternator?
- DIY Remove Timing Chain Cover & Intake valve solenoid
- pulling cam sensor from plug
- Looking for sparkplugs
- loss in power!! plz help
- NOS octane booster
- Search broke >< how much hp?
- Limp Mode - Codes P1271 & P1281
- blown engine:(
- blown engine:(
- timing cover removal?
- DIY Upper and Lower Plenum Removal
- DIY Wire Tuck
- Help - Engine knocking yesteday but quit.
- oil can as overflow?
- Dealer AWD Service Cost?
- spark plugs
- HELP!!! Replaced engine in my g now getting codes p2138 and p2128
- post your oil catch can setups!
- Temperature Gauge, Motor fan noise
- help on engine and 02 sensors
- HELP PLEASE!!!Car turns over but won't start
- Changed spark plugs Now ENGINE KNOCK
- help. what is this
- Ticking noise, AC related?
- braided catch can hoses
- What next?
- G35 Sedan D.I.Y. Stainless Steel 16 Gauge Fan Shroud/Plate (E-FAN CONVERSION)
- HELP!! AC Compressor seized
- Oil consumption, SES light pops on at dealer
- Can we get a 'once-and-for-all' answer on spark plugs?
- 2003 G35 Sedan stalling out when starting car, just put in new Battery..Any Help?
- 06x rough/click noise from engine bay (video)
- Coolant Change PROBLEM - Possible Air In System After Change HELP!
- dont know what kind injectors
- DIY Wideband Air/Fuel sensors replacement
- Igniter Coil FAILURES???
- Help with engine codes
- Y-pipe protection solutions for lowered cars.
- swapping gears
- Grinding while shifting from 2nd to 3rd....
- Advice needed on the Rev Ups
- new drive belt question?
- Cold start Engine Knock
- Lightweight battery conversion
- DIY: "Cold" Air Intake
- Bad Clutch Please Help
- Best pulley set
- transmission problem, engine wotn start
- Hesitation in starting....
- cams
- My engine took a dump WTF!!!!
- HKS Bypass Valve - Questions for Vortech
- DIY Oil warmer removal
- mounts...
- Can TT or SC be disable and enable at will?
- Starter Problems?
- 5W/20 Oil
- Starting the car in cold weather. (winter is coming D:)
- HELP oil burning and smoke
- AMSOIL....purchasing aggravation....=o(
- DTC P0605 (Internal Control ROM Error)
- Damn Oil!!
- Best setup on gears on my G35 A/T coupe and pricing
- Loud Exhaust w/nice backfire but y-pipe flex pipes seem to be making noise
- Overheating problem and solved
- question about stillen intake airbox
- Rough idle after sparkplug change
- redline??
- 350 hp with a NA setup
- Missfire, sputter, hiccup.... Fixed!
- How tell if mrev2 is real?
- HELP: low gas mileage on 03' g35 coupe 5AT
- Differential question..
- Transferring a 07 Sedan Engine to 07 Coupe?
- Fuel Injector replacement question....
- motor removal help
- Need help
