View Full Version : Engine, Drivetrain & Forced-Induction
  1. TT daily drivers
  2. Block Specs?
  3. 2007 Vq35HR JDM ecu CRACKED! Need help for US-SPEC G35c/s
  4. vq35hr's needed @TS
  5. Any regrets with Poly-Urethane?
  6. New Engine
  7. quick fast power help
  8. Has this ever happen to your G?
  9. Drain plug washer sizes
  10. rattle/clunking in the engine bay?
  11. idle dips below zero and engine stall
  12. Request: Radiator Measurements???
  13. New Parts
  14. Nitros set up???
  15. Looking for info on yaw disable switch
  16. How to do a ECU pedal reset
  17. Need info on drive shaft yoke!!
  18. Question about RPMs
  19. REV Light & Overrevving?
  20. A/T Pattern Reverse Kit
  21. WTF headers and 9 lb pully
  22. APS Single turbo
  23. spacers?
  24. M90 Supercharger???
  25. 9 Mpg ??
  26. Mechanical Maintenance
  27. Underdrive Pullys question
  28. Turbo Magazine: Turbocharging G Sedan Article
  29. bolt on mods?
  30. Problem: Starter hesitation, Starter going out?
  31. When do you replace the timing belt
  32. No more Warranty, Going FI on stock internals.
  33. stillen engine damper question
  34. Which mods do I start with?
  35. problem with Idle......help
  36. For those who had their motors replaced b/c OIL consumption!
  37. First Log with UTEC / LC-1
  38. mobil 1 question
  39. A fellow Dubai Stillen sc FX35 owner gave me this advice
  40. Superior Racing Development
  41. UTEC Trouble - Help!
  42. When i Rev my car.....
  43. Question on Installing Bung!!!
  44. Fyi
  45. Best mods...
  46. Problem with the G
  47. what kind of oil ...?
  48. my coupe?? and its power?
  49. Innovate LC-1..
  50. Why is the torque level on the new G35 low?
  51. Bogging down SOUND after new short block install
  52. Checking part compatibility between G35 Coupe, Sedan,& 350z
  53. Datalog 02 bank Question
  54. Getting More Torque?
  55. pics of Stillen engine torque dampner
  56. All Motor or forced induction
  57. Signs of a problem with a plenum spacer?
  58. Quick question
  59. Dual engine dampener
  60. Bad knock sensor???
  61. What fluid do you use for your methanol injection??
  62. noise coming from engine
  63. Verifying Planned Mods
  64. 3.5 HR may take well to exhaust mods
  65. More pics of the ORC supercharged V36 and Nismo-kitted V36 (in black!)
  66. Getting from 293hp to 350hp in a 07 Coupe NEED HELP
  67. What is the name of this part and where can I get a new one?
  68. just changed the belts on my sedan
  69. short shifter problems?
  70. For those with reflashed ecus. Sedan auto and maybe early coupe autos
  71. Stock Catatlytic Convertor Blown?
  72. Quick Question
  73. Unichip question
  74. variable valve timing ???
  75. oil to use on our G?
  76. engine ticking... or knock?
  77. Popcharger: New vs Old
  78. something not right w/ VRT....
  79. best performance add-on?
  80. ecu reset?
  81. Here is my setup for my 04 6mt G35
  82. Synthetic Oil - Summary
  83. Service schedule in PDF format?
  84. Electric Supercharger
  85. UTEC Question..
  86. engine beauty cover
  87. Oil change questions!
  88. motordyne 5/16 spacer
  89. UTEC 1K OUT THE DOOR....wat u think?
  90. Check Engine Light?
  91. Rev set question Cant do it
  92. Spring Maintenence Info
  93. UTEC - Where to buy it?
  94. So is there any gains with SAFC proof please
  95. thinking about an intake
  96. header instal?
  97. test pipes?
  98. VQ35HR vs. 2GR-FSE
  99. Another 30k tuneup question.
  100. New turbo Kit
