- Difference between oem Z tube and Stillen?
- Found a leak- need help
- help w/ motor swap! pics
- whats next
- Good oil filter and Whats a good oil to use?
- Whats causing the squeal? pulley or belt.
- Bolt/Nut help
- Need help diagnosing problem
- Does Motordyne Plenum Spacer 5/16 increase HP?
- Belt sizes for UR pulley set
- Just installed K&N engine air filter
- Anyone know how to do an "idle re-learn"?
- your opinion please.
- engine re-build
- overheating issues
- Where Did The Oil Go?
- Greddy catch can install
- fan cfm?
- J-Matic Vs S-Matic
- DIY Radiator bypass hose removal
- alternator battery wire
- Knocking from engine/transmission area?
- hesitation and bucking
- my engine isint happy :(
- idle shut down after new airfilter + ecu reset.
- A/C Valve popped on me
- help!!!!!!!!!!!!
- Shops near Philly?
- Purge Volume Control Solenoid Valve
- Bad Rotor
- crap...
- Automatic Transmission Service Schedule
- sounds like a blow off valve
- Getting a new block/ new car
- Oil Catch Can...why?
- Weird Sound
- has anyone ever fix the p1274 & p1283
- Check this exhaust
- steeling wheel hard to turn after doing a donut
- help please!!!!
- meaner louder exhaust?
- JWT Pop or not?
- Kinetix Upper Plenium
- engine does not turn over smoothly after parked
- v8 swap?
- Cooling questions need some help plz!!
- 75% of the Engine out, UPGRADES???
- P0455 Code help!!!!!!!!!!!!!!
- Location of Starter?
- How to spot a rev up engine *PICS*
- car going into limp mode
- 2003 VQ (G35) vs 2004 VQ (350z) Engine/Head
- Valvoline UOA?
- Replacing the dual mass flywheel with light weight flywheel
- P0328 ***. with CPS?
- Really bad gas consumption on 03 G35 Sedan.
- 03 G35 Sedan Engine Swap for 05
- Coolant drain and refill question....
- mrev2, or plenum spacer to go with my current setup?
- engine rebuilding ideas
- RPM is Rev'ing up high when accelerate
- RPM too high at start-up?
- VQ35de engine just broke any direct swap?
- oil cooler ~ $$
- Cold Air Intake Suggestions
- I live in KC, MO is it worth it to drive out of my way to get 93 vs 91?
- oil pan???
- Dyno test left me wondering...
- Another weird noise thread
- I have quick question
- a little experiment
- 2003 G35 Sedan Overheating
- Idle Issue *Help*
- 150psi on all six cylinders is this ok @8:5.1
- Beshoff now an Authorized HKS Dealer!
- MREV2 - remove stock lower plenum HELP
- 2* advance
- HP Difference between 2003 and 2006 coupe?
- Thoughts on Castrol Edge 5w30 vs. German Castrol 0w30 for my 05 Sedan?
- vq35de swap questions help. . .
- Anyone using 42 Draft Designs Stealth Oil Catch Can?
- g35's with stock rev up??
- Still a little confused..
- How much is a compression and leak down test?
- Squealing noise at start up and it's not the belts
- Okay To Do 80mph On New Engine?
- possible transfer case issue?
- i need measurements
- Is leaking Valve Covers really a BIG problem to worry about???
- 350z Won't start!!!
- Clutches.....Decisions, decisions
- Vibration during idle
- do cams make a difference with my mods?
- Engine temp
- Sorry if this is in the wrong section.
- Engine Noise *Found Video*
- SxExCx Ground Kit, update review
- 5 Codes showing all o2 sensors bad?!
- Rattle...Help Please
- Megan Racing Down Pipes???
