- pulley belts
- price for RB26 swap on G35
- Motor Mounts -NEED Hi Performance
- Amsoil vs Wix filters
- people use Mobil 1 syn oil..
- Ground Wire Kit
- Ecm
- g35 6spd
- How much hp will i gain?
- Question about a couple engine noises...
- The coolant control valve with iso thermal spacer
- aam vs. md spacer
- rods and pistons on ebay
- Which would you choose in the 08 ... turbo or NA
- HKS, w/ JWT popcharger and Z tube Sound Clip
- Blew the Power Steering this weekend
- Ecu part number
- service engine light
- Set up for car
- Where's a UTEC tuner in LA / OC, CA? Opinions on UTEC!
- VQ 35 motor for sale on ebay
- New Stroker Kits???
- 05' G35 blew coil pack. need help
- Amount of labor needed?
- full synthetic, not recommended?
- Who's Sharif
- Replacing Spark Plugs, One step colder or oem?
- G35 coupe + regular gas... knock sensor help !
- Why i cant get a MREV2
- Chip
- Spoke with service advisor RE: oil leaks, consumption
- Anyone have a 350Z AAM Modified ARC Catch Can on a G?
- GReddy V-manage (Variable Valve Timing Controler)
- Pop rivets
- New Hood Dampers...the good ones!
- Looking for a stock airbox for 03 sedan
- Unichip
- Do I need new belt?
- Car got dyno'd today...
- Unichip Cheap!!!!
- squealing belts wd40??????
- How many are NA and FI'd?
- Best spacer with Supercharger??
- non FI Performance
- chain dragging noise
- Did Infinity change motors mid 2006 - oil burning question?
- Bov?
- Any modification for better gas milage ?
- headers help
- What Samco Hose is this? (maybe G352NV can help)
- Purolator PureOne PL14610 Revised
- Does this happen to your G??
- Whats this cooler for?
- hks f-con iS
- Synth blend to mobil 1 back to blend
- G Sedan Issue HELP
- Plenum spacer
- Spark plug which has the highest conductivity?
- Temp guage after oil pan spacer install
- help
- Does the VQ35 have replaceable coilpacks?
- 350z & G35C y-pipe the same?
- Greddy SP2 Install - how to make tips flush? see pix
- The big question? which is the best turbo?
- HKS Supercharger discountiued?
- does ztube/pc combo affect mpg?
- polished z tube?
- Car won't start.
- what i must do now???
- What Do I Do Now??
- help, oil leaking from top plenum!
- Anyone had any dealings with Uprev????
- What mods with $2000 budget?
- Engine Oil coolers
- Difference in 04 vq35de vs the 05 Rev-up?
- First Oil Change
- Engine Problems Already
- 5AT Dyno Pulls
- Goin N/A need some susgention and commment
- Oil Analyses Results posted...3 Years' Worth of Oil Analyses, '03 sedan
- Z-Tube Pics? Install?
- ztube and jwtpc question
- Cold Start Clicking Noise
- Metal in Oil!!!!
- considering going nitrous.. please help
- Crawford Plenum vs Motordyne Plenum 1/2" Spacer
- Evap Code
- G35 General Maintenance...Easy to do it yourself?
- Whining noise comming from engine compartment
- Find out if you are being ripped off for less than $100
- any HP gains by having Mrev2 ported/polished
- TS hood + Rain Guards
- 5/16 Iso Thermal Plenum and Resonated Race Pipes install
- Strange Rattle at slow speed
- VQ40DE in G
- Oil and filter
- 2003 with 4100 miles! What Service should I do?
- Braille battery & mounting in G35
- why does my coupe feel sluggish?
- MREV2 vs 1/2" Plenum or Both
