- Powerlab fitment for an 06 g35 6mt
- Spark plug help..How tight should they be?
- New Tranny question
- nissan matic s and oem coolant prices
- LUK Dual mass flywheel is OE!
- Help please: Car dies and runs sluggish
- Injectors? brands?
- 2006 G35 AT check light is bugging me !!
- Gaskets for Borla Headers
- 04 G35, air rushing sound at PCV
- UR pulleys
- 60-100mph Times?
- How do you remove the pilot bearing
- 2003 Sedan wont start
- gas smell under the hood
- Intake work possible effecting Oil Consumption!
- Clutch & Flywheel bolt torque specs
- Ignition Coil Oil Leak??!!
- Serious help needed here...
- Plenum spacer void warranty?
- Loud shrieking sound. Help!!!!!
- Looking for a Throttle Body Bolt.
- Who makes the OEM dual mass flywheel?
- Which clutch should I purchase
- New to G35Driver, 2003 G35 Coupe question
- 2008 ECU Reset
- Worlds first closed deck VQ35
- 300 hp NA V35??
- The best gas???
- Throttle Body temps in winter (with isothermal mods)
- Looking for exhaust on g35 coupe 2006 automatic
- Engine pulley making noise
- Starting Issue
- real electric supercharger?
- transmission hose
- Need help issue with the tune on my vortech kit
- Nismo flywheel questions?
- NEED HELP ASAP RPMS up down up very weird
- LUK Dual Mass OEM Flywheel?
- Oil consumption prob
- my hybrid V35 plan
- KineTix Question
- GTR bonnet vents
- vdc off, slip on
- Engine is SMOKING PLEASE HELP!!
- HR Short Block
- Help Guys,pleeease!
- [DIY] Upper and Lower Plenum Removal
- Check this out
- Anyone know where i can get another cap
- 1st Gear high RPM's
- Black Smoke from Exhaust under acceleration and Compression question
- Engine ticking
- 31lbs. OEM Dual Mass Flywheel vs 27lbs. Single Mass Flyweel?
- check engine light emissions
- P2135 trouble code service engine soon
- Highly Strange and Unexpected Engine Issue
- How to replace an OEM ECU for my 03? HELP!
- What size spacers i need?
- SLR performance chip!
- This cant be good... Coolant/Antifreeze
- OBD-II Sensor Location
- CEL's
- rpm's help fast please
- grounding kit
- de-pinning MAF plug
- slight change of drive belt
- what mods i need to gain 50hp?
- SPEC Single Mass Steel Flywheel or LUK Dual Mass Flywheel?
- Independent Dyno Test: VQ35DE RevUp + Plenum Spacer
- Titanium Engine cover and Radiator spliter
- Angled Plenum or "level" Plenum
- need help ASAP (crankshaft pulley wobbling...)
- when to fuel up?
- OIL/TRANS cooler question
- now what?
- Car won't start, AT Check light flashing, fan motor comes on - what's wrong?
- triptronic issue and more
- Aluminum Floor Jack on Sale
- 6mt swap offer
- First GTM G37 SC
- Is this a Throttle Body Issue - Help Please !
- Electric fan
- Leaking valve cover write in campaign
- Complex Code Failure G35 2003 SEDAN
- headers hp?
- COBB Post MAF Hose for G and Z Available Now!
- wireing harness question
- AC only works on 60!?! WTF
- Using Revup engine in none revup Z?
- engine questions
- lightened pully set qustions
- Buying parts off a tuned '04 350z
- Iridium Spark Plug heat range?
- 2nd Oil Consumption Engine
- PLEASE PLEASE Help
- Engine swap..what has been done and what is possible?
- SES Light: P0138 Rear O2S, Bank 1 Maximum Voltage Monitoring
- Soooo if we have LSD (well I do), why do we have ABLS?!
- Why does the clutch/flywheel chatter? It's random..
