- Tranny & diff fluids????
- radiator spewing out
- Gears 1-4 shift fine but when I get to 5th it's like I'm in neutral... :(
- engine harness while engine in car?
- any differance in brands of injectors?
- VALVE COVERS RTV or NO RTV???
- Want to add 3.67 gears just for the strip? Here ya go
- Oil overfill... Fvcking mechanic....
- Clutch ticking noise
- want to make 20+ hp
- Check those PCV valves
- vq30de heads
- Oil usage on a non-rev up 03 VQ35. Weight choice on the next change?
- oil leak!
- Motor stubles and dies at Idle
- My exhaust is resting on my M-Brace.. is this bad?
- Grinding at highway speeds
- Bad Vibration!! Help!!
- Oil Pressure Light
- CAM Sensor Replace 05 G35 Sedan
- Need advice on engine problem
- Lack of performance?
- Some sort of switch for Exhaust ???
- PCD Performance Chip, Worth it??
- Built n/a motor and oil consumption
- 2006 G35 Coupe 6MT Noises
- 350hp
- Titanium Bolt Upgrade! Big Ballers in the House!
- Does having the CEL on bog down the engine?
- TopSpeed Pro-1 Exhaust: Installation & Review ( with pictures )
- 2 Nissan Data Scan II users
- Ecu chip
- Walbro Installion - Performance Modifications ? ? ?
- Best Intake - Poll / Review
- Oil in 2004 6MT coupe
- Need Advice on Replacing my motor
- plenum spacer PROBLEM :( need help
- ECU Flash, UNIchip, Osirus?
- code: P1148
- Mishimoto Radiator
- very confused right now....
- Kinetix Manifold and motordyne plenum spacer?
- 4.15L G35 in progress at Zcargarage and Rebello
- I need some help
- Where is the G35 Fuel Reset Switch?
- Please Help
- Just finished replacing the valve covers.
- Surging when releasing throttle
- How do you relieve fuel pressure?
- Is a Hybrid VQ40DE possible?
- Throttle body cleaning
- Running rough and is it rich or is it lean?... troubleshooting...
- Spark Plug Questions (anti-seize and gap)
- Will the G37 headers fit on a 05' G35
- Motordyne copper isothermal hose fitment
- anyone using an aftermarket breather tank?
- Recommendation on Bolt ons.
- Horsepower - Mods - Expense
- revup engine work w/ nonrev engine harness?
- Clutch Problem!??? HELP
- Need new motor mounts any suggestions?
- 1st gen g 2nd gen motor
- Random No Start... FFFFFFUUUUUU!!!!
- Engine and AT question
- How can you tell if I have reset my ECU successfully?
- eliminated engine pinging completely
- Cylinder Numbers
- bad fuel mileage / Mas air meter cleaning?
- how to change transmission oil
- Q n A about DIY Oil Change and which oils to use
- Twin SUPERCHARGED g35
- P0302 Misfire Cylinder 2
- assistance needed....long story short hole in gas tank...
- more torque...
- 5AT Revup
- Bottomed out -- something is leaking ...
- Leaf Blower Turbo
- NISMO Thermostat
- Engine Whines When Turning
- Help with camshaft position sensor
- Need help: Experiencing some problems (clicking, squealing)
- Is there A DIFFERENCE with a sedan to a coupe motor?
- Motor Oil question
- Engine Noise??
- car starts, idles and then turns off! Only turns on if u give it gas!
- Possible OIL CONSUMPTION NEED HELP!!!
- Clutch Flushing/Bleeding Should Be Done!
- AFR Gap
- Coolant reservoir empty, fvck
- Our Dipstick is retarded.
- g35 coupe won't start
- 2004 G35 Coupe Mechanical PROBLEMS! HELP ME !
- rev limiter?
- Nitrous
- Does 350z UNICHIP work for G35? Is It Good?
- *SOLVED* Engine Startup Clanking Noise, 2005 G35 Coupe. (With Video)
- Crank Key
- Lack of Power, Dealer Says Nothing Wrong...
- nrg oil catch can??
- engine covers
