- Rattling at high RPMs
- 1 year oil change???
- Congrats TTrank on the Modified mag article.
- goin cam...help
- N/A...help
- Random NO Start? Only at Night...
- Bell Works paddle shifters on an 03 sedan
- cosworth/HKS difference on dyno
- question about hoses.
- Jwt Intake Installed ! but have a question
- Anyone Ever Use Zmax?????
- New owner...have some questions about oil consumption
- Does the '05+ auto VQ engine have oil consumption problems?
- i need engine mounts 04 6mt
- spark plugs
- "RATTLE" Please help.
- Plenum Spacer question (sedan and coupe)
- Time for Change... help..
- Switching engine oil
- Does 06 6MT Skyline 350 gt has the same issue as G35 (Oil Consumption issue)
- Rear Drive Axles Question
- engine misfiring after wire tuck
- HELP! Weird Problem!
- meed clutch assitance please
- NEED HELP! "what belt is this?"
- pulleys a bad idea??
- Fuel line
- spark plugs!
- Is there a Infiniti mechanic here??
- Water in my donor motor. Can it be saved?
- 06 Coupe Idle issues
- Throttle body relearn (manual vs electronic)
- Getting a P0442 code please help!
- Cons of driving with a bad throttle body?
- Quick question for someone with the service manual handy
- Quick Synthetic Oil Question
- Help!!! Transmission rattling...
- ENGINE OVERHEATING! need ur input
- Need help did my oil change and all only 2 1/2 qts came out
- Mechanical fan to electical
- Plenum Spacer and warranty issues
- Help!! No pedal response
- Bolt-ons before the tune!
- Cobb Tuning AccessPORT or osirus
- problem with low rpms at idle
- Edelbrock Twin Turbo Kit
- 5/16 spacer installed but...
- RHD battery cover fitment
- Vortech- Gates Belt?
- Camshaft Position Sensors
- Need help!!!!
- Kinetex Plenum or Spacer? Cant decide
- Forged Performance Announces new Website: Version 2.0
- compatible
- Shattered Dreams
- Anyone Replaced a Knock Sensor Harness?
- please help with code P0300
- HELP !! Oil found in cylinder #2 & oil deposit found on ALL 6 plugs. PICTURES INSIDE.
- HELP !! Oil found in cylinder #2 and oil deposit found on ALL 6 plugs. Now what...
- Custom grounding wires
- Door Trim
- oil filter for g35
- Well i guess slight rattling in idle is NORMAL with VQ35DE engines?
- Service engine soon,VDC Off, Slip lights on.. probs..
- turbo/supercharger
- Help. My gear snapped. What can cause it?
- rareJDM Engine Harness Cover - Anyone have one yet
- Cold Air Intake
- more power
- Motordyne Plenum Spacers.. 5/16 or 1/2???
- Cleaned Throttle Body, now SES Light On...
- Pathfinder cooling mod
- Blown Engine: 03 Sedan Stock 112k
- Computer thinks oil is spent?
- OEM Coolant Online??
- engine code
- Enigine code. Need help
- Sfl, u.s. 27 friday night.......?
- 03 coupe: vdc, slip, check engine light on after changing spark plugs
- Greddy TT
- First coolant and atf drain / refill...impressions
- Cleaning up the engine bay
- weird sound when I started up my g
- Wheels Vibrate at low speed
- engine turns off while driving...help!!
- from MT to AT????
- Spacer differance????
- Thermostat
- Building a motor??
- Unhappy looking Dyno..
- Valve lash adjustment
- Changing my own oil
- 350z rev up
- VQ35DE Intake Cam Gear? IVT?
- bank 1 and 2 running lean?
- Air relief plug(s)...1 or 2?
- Noob ECU question
- HELP! snapped the top studs that screws engine cover down
- Anyone know what this gauge is for?
- Coupe Engine
