- SxExCx products / services *SHOWCASE*
- Tried search button already, Motordyne Install
- Underdrive advice...
- Loctite for MREV2 install
- I need help with Relays
- belts squeaking again , dealer says replace AGAIN?
- Engine oil - Conventional or switch to Synthetic?
- Valve ticking
- just a question ????
- cobb accessport
- Seafoam? Does it work?
- Vortech, gatorback belt issue...
- Found deals on Greddy CF air diversion panels $90 shipped
- Why is there oil on intake cylinder wall?
- Won't Start, Radio works but no lights power door locks, windows, wipers or turn sig.
- airbag warning light-wont go away
- Upgraded cams -- Who has them? Need some info.
- will this radiator fit on my 03 sedan A/T
- kinetic velocity manifold..is it worth it?
- G35 6mt engine rebuild help
- Need your help on removing oil filter
- need help asap spark plugs
- whats better HFC OR TEST PIPES?
- Need a diagnosis!!!! HELP!!!
- question
- Vdc off, slip and service engine soon lights come on
- Connecting Rods
- lower MPG after spark plug change
- what size plenum spacer?
- rev and blinking light
- Motordyne xyz pipe question
- I'm in this large debate..
- HELP PLEASE!!! blown fan and water pump pulley!!!
- VK50 Swap possible?
- went to ramsey infinti today warranty info
- sorry if im reposting. Ringing sleigh bell like sound from engine
- Md 5/16 instal....help!!
- spark plugs
- idle air control valve
- Camshaft Drive
- needs some advice. need some tips
- I need some help
- vortech fmu
- Running little hot
- car died tonight at idle....
- G35 lost some of its pep.
- Random Temperatures while driving (04 AT)
- eBay Catch Cans...
- what engine came in an 2006 350z 6speed convert...
- SSV "Velocity"
- SSV "Velocity" Questions
- Octane ratings...
- g35 coupe plenum spacer ?
- Do you lose any power
- Cleaned TB - High Idle
- Nos octane boost
- Help with Mechanical Fan Removal
- Weird Knocking-Like Sound
- ***car turning off while driving??!!!
- need help with performance for n/a coupe
- Anyone got a coupe/z thermostat on their sedan
- Bad Throttle Chamber
- Food for thought at your next fill up
- Need Help with Cams
- Installing HKS DLI and NGK Spark Plugs today (need some advice)
- Injen CAI in the Rain??
- g37 swap?
- Cosworth heads install
- Changing oil how often?
- Question about gauge cluster
- Cooling Plates
- Haltech VQ35DE Platinum PnP EMS
- Car bogs out. advice.
- oil consumtion and MREV2
- What are the consequences of undertightening your belts?
- Plenum Spacers
- Another Oil Question
- pistons and rods
- New G35 owner seeking advice
- boost or all motor?
- 04 g35x throwing cel code U1000 need help!
- Guess what
- Ticking from engine area when cold
- Early 2003 ECU
- >2.5quarts out on change, how bad am I screwed.
- Return Fuel System Guys... IN HERE!
- 03 sedan with cat inefficiency code? why?
- its turbo time ;)
- loss of HP
- Z-Tube Question
- '04 g-sedan chirping noise
- WHich oil filter
- Question on Amsoil 0w-30 syn oil
- Jim Wolf S2 Cams Installed
- Koyo Racing Radiator Question
- whats the benifit from porting and polishing the heads?
- Oil Pressure Gauge?
- P0455 Trouble code
- Pulled plugs and found oil
- Did the Basic Mods, What's next for power?
