- Buddy Club Racing Spec Condenser
- AEM Wideband O2 Sensor Location
- Fuel Rail
- Need Help Disabling my RAS
- For those of you who have coolant temp gauges or know the OEM coolant temp gauge well
- Oil Change
- Clicking/grinding under acceleration?
- what kind of motor oil?
- Are stillens intake+catback hp gains accurate?
- Question about Redline
- Car not starting....!?
- I need help finding a tool
- Car burning alot of oil
- N/A Mods for 06Auto sport package????
- Engine blow by
- Blox Intake Spacer,
- Brake Light?
- Aftermarket tachometer
- Is racing Fuel Good or Bad for our G35
- Rev-up???
- Does anyone have autometer Auto Meter Sport-Comp DPSS Gauge?
- blown motor
- A/C Compressor: are there different ones for the coupe and sedan?
- Finally..My Customize Exhaust :D:D
- powerlab 3/8 spacer vs. MD 5/16 spacer
- Problem starting up
- Low-End HP Question.
- installing spacer
- Chainging Oil HELP- first time !!
- how often should you replace your air filter and cabin (microfilter)?
- Shaking from the front of the car during turns- G35X
- High Idle, VDC, SLIP, SES light on.
- Mystery Box?...
- can you sell a g35 with test pipes?
- Motordyne spacer
- best performance N/A upgrades
- Grounding kits outside of SoCal
- power seat problem
- Is the dreadful oil issue only for 6mt owners????
- boost !!!
- DealerShip Nightmare Story
- only option is NISMO??
- Question for those of you who have recieved a warranty replacement longblock
- Poll : Oil Consumption (For those who aren't)
- Pulstar Plugs melted to my coil packs
- Pulstar plugs melt to coil packs
- Need a torque wrench?
- P0507 = I'm an idiot...help
- Oxygen sensor
- How can you tell if you sucked some water into your motor?
- 1/2" MD spacer install?
- Power Steering Fluid leak?
- Z1 Motorsports Plenum Spacer
- service engine soon..
- Oil Cooler O-Ring???
- CEL Codes without OBDII Tool?
- Oil consumption if switching from dino to syn
- having car trouble w/ steering
- Need help finding a replacement battery for my coupe
- Block Stamping / Identification
- Spacers?!?!?!?
- oils
- oil change today!!
- My car is angry...
- Motor oil question....
- Calling all 6mt Rev-Up Engine Owners..
- shops in Socal that does FI installs
- Clearing Engine Codes...not working
- Cleaned TB..Now the car heaves
- Check engine light. Need help.
- D to Tiptronic Rev differences!?
- Car Seems Slower 2 Days After Spacer Install
- Wanting to Raise Idle - Dealer, UTEC... what's the best way?
- so i went to the dealership today
- JTV racing headers?
- New..
- Tune Up Help
- VR38DETT G35 Swap
- Utec install with pics
- Kinetix Racing SSV Extreme Flow Manifold
- Question about Cams.
- Where to get car tuned in Maryland
- Mobil 1 Fully Synthetic 0w-30
- Anything possibly we can do...
- spacer help
- White Smoke, Tapping Noise and Sludge
- E85 Conversion Kit
- my oil change questiosn... 15w40 alright?
- Rattleing or loose nut and washer sound 3k+ RPM
- Before/After Mod Info
- Anyone try a Sprint Booster?
- 03 G35 Coupe > Performance Chip ?
- Spark Plugs
- Codes P0455, P1273, P1283
- Complete Engine 04 w/ 35k miles 6-Mt What is it worth?
- Any one tried
- bogging out(assistance please)
- Help Please!!!
- How To Remove Timing Chain Cover, Valve Cover, Timing Chain
- Unleaded ok, gas milage?
