PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
  1. battery keeps dieing
  2. Stablizer Bar
  3. Seafoam
  4. Engine noise
  5. ?'s about Motrdyne spacer and AT G...
  6. Repetitve whistling noise
  7. Pulstar Spark Plugs
  8. OBD-II code PO-128?
  9. Engine shuts off after 1/4 mile at the track...
  10. '06 6MT, Burning oil/engine replacement
  11. performance help anyone?
  12. Throttle Body Bore
  13. Intake, Plenum + Spacer Question For 04 6mt Twin Turbo??? Please Help!!!
  14. Plenum Spacer
  15. Is this product on the "Up and Up" or is it B.S.?
  16. Copper Plenum vs. Normal
  17. what oil should i use??
  18. Choosing engine oil. Help needed.
  19. Rough Idle after MD spacer Install- HELP
  20. squeeky steering wheel column
  21. Gates Brand Belt Part Numbers
  22. synthetic to Dino
  23. Penzoil Platinum Synthetic
  24. SES code p1122 HELP please
  25. engine noise
  26. What does REV mean?
  27. ECU pin out diagra for 04 G35 sedan (manual)
  28. Cosworth Plenum for VQ Revup
  29. Rev Up
  30. New to forum and need help
  31. loseing fuel
  32. Spacer & Plenum?
  33. 5.2whp for cheap
  34. Iridium plugs
  35. Small clicking type sound in the front left
  36. Anyone increase their redline?
  37. Customize an intake?
  38. project 2k
  39. service
  40. Click, Click, Click, Click!!!!!!!
  41. Coolant controle valve for Motordyne
  42. What Cams to use???
  43. Checking your oil how to?
  44. How often do you change your oil?
  45. '03 Coupe AT - Starts strong then dies!!!
  46. what do think
  47. can't fill my gas tank
  48. Rear active steering
  49. Cool new Kinetix SSV engine cover.
  50. What to get instead of a coupe midpipe?
  51. Gas Mileage with exhaust?
  52. 06mt Rev Up DUD - Insight and Opinions Needed
  53. plenum suggestions
  54. weird sound at low rpms in 2nd gear
  55. Best prices for mods?
  56. Morning starting problems!!
  57. Throttle body service???
  58. Transmissiom Chatter
  59. Header Gasket Leak
  60. best intake?
  61. Power Steering Fluid
  62. Oil pan plug spout
  63. Does anyone make...
  64. 30,000 Mile Service from Nissan?
  65. Oil question
  66. Oil Pressure Sender
  67. My oil consumption story = leak, normal, or just synthetic?
  68. APS Tall Boy
  69. Sythetic Fluid Conversion
  70. 20 hp, an easy upgrade?
  71. What The Hell Easy 35hp?
  72. aps upper plenum with intake
  73. should my procharger B loud??..REALLY loud!!
  74. what internals?
  75. Wideband guages
  76. exhaust smell in car
  77. Best Synthetic Oil to use?
  78. smoke coming outa engine
  79. Water Injection
  80. Apexi AFC NEO
  81. Help! Flucuating Temperature/No Heat after Coolant Flush & Thermostat Change
  82. 2 questions...need help
  83. exhaust
  84. Clanking sound??
  85. Tapping noises after installing a new plenum, is this normal?
  86. really stupid question- how do i check my oil?
  87. Turbo Question
  88. Raising Idle = Problem Solved?
  89. AEM dry filter?
  90. Which Belts for U.R. Pulleys??
  91. "Spare" stock ECU for reflashed ECU?
  92. grounding kit?
  93. oil pressure
  94. Mod your stock G-Tube?
  95. Oil Nissan 5W-40. Any good?
  96. Air Filter For Procharged G35/help!!
  97. Spacer Q?
  98. Why so little talk about lightened pulleys?
  99. Apex'i N1 ExTi single exit, 05 Coupe
  100. Going to change my ignition coils tonight, any tips?
