- Will it fit???
- blower?
- I want to learn how to tune engine
- Will MREV2 Work with Kinetix Plenum
- Messed Gas Gauge?
- 06 Z-tube fits 04 G35 coupe?
- welp, it's begun. Oil Leaks and only 58K miles.
- 350Z engine cover won't fit????
- Check out what I made for the VQ35 platform.
- WTF..Shut off in the middle of the Road
- non rev-up max n/a hp
- Painting TB
- Check Engine Light
- Cosworth Intake Manifold vs. Plenum Spacer?
- CEL on after TB re-calibration when blipping feul
- Supercharger
- Can someone give me the part number for K&N air filter?
- Procharger oil change
- Mixing oil when oil level is low?
- Nismo header?
- Nippon (eneos) motor oil
- Procharger
- 06 6mt engine replacement
- sorry guys another synthetic oil question
- What hp gain from Stillen G2 exhaust + Ztube + hiflow intake
- hks turbo/supercharger
- Check engine light on...... HELP ! ! ! !
- Is 5Qt oil enough for G35 ?
- No gains from intake, exhaust, and 5/8" spacer
- air mass sensor affects car reving ?
- engine rebuilt
- Low 5 sec 0-60 Bolt Ons
- AMSOIL Distributor. Have had no luck
- g35 ecu upgrade
- Has anyone used the Kinetix SSV intake??
- Arc v.2 catch can installed..pics
- relays
- Installing Z Tube! Question
- wont start
- Will 20' rims void warrenty if I need new Transmission?
- The best N/A Fuel Controller ??
- Maintenence question
- Car shutting off at start up ???
- Any ideas on what exhaust tips to get?
- Who has the Kinetix SSV intake manifold?
- HP increase combined MODS.
- G35 70MPH @3000 rpm is normal?
- my G is knocking at your door!
- Thermostat for 5 AT - Information
- boost problems
- Do all G35 6MT consume excessive oil?
- 2JZ-GTE in a G35...?
- Another dreaded oil question
- p0507 on my g35 help?
- utec
- not sure where to post this..
- stillen engine damper
- quick question
- Engine stalling with newly added mods...
- A pillar dual gauge!?
- engine question
- spacer and K&N CAI
- Aem Wide Band air/fuel Gauge
- Should I Get The Mrev2??? What Is It??
- Forged Performance: 2008 G37 Coupe Baseline Dyno
- Throttle Response...Gone
- need help!
- Injen CAI + Rainy Weather
- invidia g200 packaging question
- RevUp question
- VSS Plug/Wire/Tapping Point
- What's the horsepower on 2007 G35 coupe?
- What motor oil to use for 2007+ G35 sedan?
- Oil Change every 3K? What a joke.
- Amsoil Coolant??
- What Should I Get Next??
- Repeated Coil Pack Failure... Please Help..
- APS TT... two questions ???
- Torque vs power
- How long to wait for new engine???
- spark plugs and chips
- BIG problem...
- fluid leakage
- how to?
- Fishtailing and rightward pull
- Going TT need advice
- Which Color Locktite???
- ECU Problem
- Pulstar Pulse Plug
- Help...
- Oil change every 3 months needed?
- Pop Charger kit or NISMO or Injen cold air intake?
- Quick question... What it fits...
- Which oil to use after 65k miles?
- Test Pipes / High Flow Cats
- Check your plenum bolts if you have a spacer
- Is it ok to tap into this wire???
- water temp guage install
- Servicing the G
- g35 engine tuning questions??
