- g35 engine tuning questions??
- Brake warning light?!?!
- Plenum question
- Best Bang for the Buck????
- Crank Pulley bolt won't come off
- Larger Oil Filter, Why Not????
- need some feedback
- everyone know about UNICHIP?
- Having problem getting my car into reverse (04 6MT).
- T-Clamps needed!
- Gauge Mounting Question
- New Owner...Best bang for buck!
- service engine soon ???
- Mass Air Flow Sensor
- Difference between Ceramic and Stainless Headers?
- N/A gauges
- How can i tell the G tube and Ztube difference?
- Which oils for '05 G35X AT
- Fuel Pump Relay Location
- Cracked Radiator Was Replaced; however, Car Still Overheating.
- VQ Oil Analysis and Info
- Samco Question
- Couple oil questions...
- German Castrol Syntec 5W-30?
- the DIY fake bov
- Do you think this will stop engine from burning oil?
- Intake question
- Engine bay Covers
- Intake ?
- Throttle Body?????
- oil??
- Need some advice on mods...
- Amsoil
- SSV Extreme Flow Kinetix Manifold on N/A???
- Please Help
- Shell Spirax 75W90 in Transmission
- replacing vq35de internals
- Noise when starting
- When dipstick reads low, how many quarts are gone?
- Evap canister question
- enine damper on APS TT? possible?
- Rough Start + White Smoke
- Project: BUILT VH45DE TT on a G coupe
- Cheapest place to buy OEM Oil Filter?
- Bolt/Hardware Kit??
- Alternator pulley help!!!!
- The Invisible Hood Vent: Engine bay cooling mod
- Engine cut out
- Intake and Chip advice for a Newb.
- STP Gas Treatment
- What Cold air intake to I buy?
- straight pipe?
- Engine Heating up, should i worry?
- SHAKER HOOD - Stillen Supercharger
- Oil change frequency?
- test pipes or HFc on this g
- Ground Wires!! Anyone have them? Any Positive/Negative Feed backs?
- MREV2 & 5/16 spacer or FI HFC
- Intake
- HELP!! No Fuel No Spark 03 G35 Coupe 6mt
- CARB legal papers for the cops..
- Nismo CAI to short ram?
- Odd oil filter issue...
- stalling out
- Vortech Supercharger Question
- Idling?
- Whining noise from engine compartment
- turbonetics installation guide
- Well, it finally happened...
- A leak from my plenum?
- I need more boost!!!
- Low RPM's why???
- question:very interesting one
- Rack and pinion leaking
- Burning oil, new engine?
- The little G that could start....NOT
- 2003 G35 Sedan 4k to spend on mods, what would you do?
- DC sports headers
- bah engine failure
- nismo thermostat
- engine vibration/shake
- what are my chances of buying a g35 that burns oil?
- I don't know what exhaust I have.
- Stock 06 G35 - RWHP?
- Easiest Way to Reach 300hp from Stock
- want to build my car up to 300whp possible?
- pros and cons of different plenum spacer sizes ?
- cold air intake question
- intake system on 07 6spd G
- engine idle is messed up
- Dumb question
- How to correctly reset the ECU?
- blown radiator?
- Cats Or Test Pipes???
- Vortech install and G35 AT SEDAN...Issues??
- Are Engine Dampeners Worth Getting? Opinions Please!
- Problem with TEST PIPES???HELP?
- G35 Coupe , What type fuel , octane ,
- Apexi Safc? N20?
- ceramic header and stainless header
