- Oil issue recall or warranty?
- top speed engine damper question
- Headers?
- What about a S/C'ed daily driver?
- Motordyne manifold
- SFR manifold
- Just had my UR pulleys installed with Gates Belts...NOW LOUD SQUEELING NOISES.
- 03 Couple g35 stalls out
- OEM Z Tube, Stillen Z Tube, Or Carbon Fiber Z Tube?
- unknown sound coming from engine
- Oil Weight choice?
- Purolator better than Most oil filter brands??
- I need Help!!!! my g acting weird..
- How to force manual start on 6MT ?
- Thoughts on Kinetix intake manifold
- Internals Upgrade vs. Buying Built Block
- Just installed my HKS!
- Low RPM or normal?
- Need following parts
- Suggestions - $1000 to spend
- MOD(S) What Next {MREV2+5/16 Spacer}
- electric supercharger???
- Has anyone heard or seen pics of the cosworth's new plenum for the vq35
- Best plug & gap. (05' 5AT coupe)
- for those of you with NOS
- spacer+mrev2
- Question about UTEC
- Turbo timer Location
- 4 Questions about the 5/16" Spacer + Mrev2
- Sale at AutoZone: 5 qts. Mobil 1 & Mobil 1 Filter - $29.99
- Car Suddenly Shut Off...
- Srs Dual 3" Catback Exhaust
- HKS and Crawford cats - 05 revup
- oil consumtion threat- how wide spread?
- Oxygen Sensor question...
- Help with P0174 please!
- Trim on JWT Pop charger heatshield fell off
- Error Code
- Lights blinking.
- Help Getting Conflicting info on Parts for TT build
- Cosworth + TT build picture blog
- blew my motor
- Carbon Kevlar?????+a little review
- Help: Missing pieces from Skunk2 spacer kit
- Painting/Chroming Plenum
- HELP: Heatshield Trim
- ***Need help from all***
- Turbonetics pre-reqs
- fuel fuse
- Pulled ECU code : P0302 | Now what?
- Think I caught the mod bug
- synthetic oil
- 06' M5 Dyno HP
- Is this right?
- Whos not happy with the Mrev 2?
- Pics of VRT working out of Mikes House!
- Warranty issues with MREV2 and spacer?
- will the utec work
- Post Your Pics of g35's Rockin' Topspeed Pro 1 Exhausts!
- Gauges...need advice
- low end power
- HELP! SEL and oil light on.
- plenum spacer and mrev questions
- Anybody do a wire tuck yet?
- 1/2 motordyene vs 5/16
- D.C. area tuners
- mrev + spacer 5/16 1/4 mile times.
- PE double row radiator
- Car starts and dies after battery replacement.
- NEED A Quick REPLY
- Installing Motordyne items
- mod crisis!
- Okay My Dilema!!!!!!your Opinion
- My battery or alternator is jacked, or not?
- performance shops in orlando area
- Looking for a neater style under the hood...
- Cold engine/oil?
- stillen grounding kit question
- Help: Oil Filter
- my dang check engine light wont go away! ERRRRR... WTF?
- how loud
- question about my first mod
- Nissan Sport Horns for CPV35
- stand alone question
- Engine Knocking
- Mobil 1 5w30 synthetic $19.xx at WalMart
- Gas Mileage after MREV2 and Spacer
- MY G keeps turning off!!!
- engine light
- Off the wall engine question
- Knocking
- exhaust,headers & K&n cold air
- screeching noise at start up?
- Engine misfiring???
- Osiris as Launch Control or two step rev limiter!
- do i really need a stage 2
- TB Cleaning
- "Servie engine soon" light
- Fuel Injector cleaner
- Compression Test
