PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
  1. Thinking about UR Ultra S Crank Pulley: Set or Crank?
  2. Aite...should I reset my 2005's CPU???
  3. Engine Knock
  4. TT daily drivers
  5. Block Specs?
  6. 2007 Vq35HR JDM ecu CRACKED! Need help for US-SPEC G35c/s
  7. vq35hr's needed @TS
  8. Any regrets with Poly-Urethane?
  9. New Engine
  10. quick fast power help
  11. Has this ever happen to your G?
  12. Drain plug washer sizes
  13. rattle/clunking in the engine bay?
  14. idle dips below zero and engine stall
  15. Request: Radiator Measurements???
  16. New Parts
  17. Nitros set up???
  18. Looking for info on yaw disable switch
  19. How to do a ECU pedal reset
  20. Need info on drive shaft yoke!!
  21. Question about RPMs
  22. REV Light & Overrevving?
  23. A/T Pattern Reverse Kit
  24. WTF headers and 9 lb pully
  25. APS Single turbo
  26. spacers?
  27. M90 Supercharger???
  28. 9 Mpg ??
  29. Mechanical Maintenance
  30. Underdrive Pullys question
  31. Turbo Magazine: Turbocharging G Sedan Article
  32. bolt on mods?
  33. Problem: Starter hesitation, Starter going out?
  34. When do you replace the timing belt
  35. No more Warranty, Going FI on stock internals.
  36. stillen engine damper question
  37. Which mods do I start with?
  38. problem with Idle......help
  39. For those who had their motors replaced b/c OIL consumption!
  40. First Log with UTEC / LC-1
  41. mobil 1 question
  42. A fellow Dubai Stillen sc FX35 owner gave me this advice
  43. Superior Racing Development
  44. UTEC Trouble - Help!
  45. When i Rev my car.....
  46. Question on Installing Bung!!!
  47. Fyi
  48. Best mods...
  49. Problem with the G
  50. what kind of oil ...?
  51. my coupe?? and its power?
  52. Innovate LC-1..
  53. Why is the torque level on the new G35 low?
  54. Bogging down SOUND after new short block install
  55. Checking part compatibility between G35 Coupe, Sedan,& 350z
  56. Datalog 02 bank Question
  57. Getting More Torque?
  58. pics of Stillen engine torque dampner
  59. All Motor or forced induction
  60. Signs of a problem with a plenum spacer?
  61. Quick question
  62. Dual engine dampener
  63. Bad knock sensor???
  64. What fluid do you use for your methanol injection??
  65. noise coming from engine
  66. Verifying Planned Mods
  67. 3.5 HR may take well to exhaust mods
  68. More pics of the ORC supercharged V36 and Nismo-kitted V36 (in black!)
  69. Getting from 293hp to 350hp in a 07 Coupe NEED HELP
  70. What is the name of this part and where can I get a new one?
  71. just changed the belts on my sedan
  72. short shifter problems?
  73. For those with reflashed ecus. Sedan auto and maybe early coupe autos
  74. Stock Catatlytic Convertor Blown?
  75. Quick Question
  76. Unichip question
  77. variable valve timing ???
  78. oil to use on our G?
  79. engine ticking... or knock?
  80. Popcharger: New vs Old
  81. something not right w/ VRT....
  82. best performance add-on?
  83. ecu reset?
  84. Here is my setup for my 04 6mt G35
  85. Synthetic Oil - Summary
  86. Service schedule in PDF format?
  87. Electric Supercharger
  88. UTEC Question..
  89. engine beauty cover
  90. Oil change questions!
  91. motordyne 5/16 spacer
  92. UTEC 1K OUT THE DOOR....wat u think?
  93. Check Engine Light?
  94. Rev set question Cant do it
  95. Spring Maintenence Info
  96. UTEC - Where to buy it?
  97. So is there any gains with SAFC proof please
  98. thinking about an intake
  99. header instal?
  100. test pipes?
