- Intake Plenum
- 1/2" Spacer Installed
- Clear Bra
- Questions on Superchargers & Other Mods
- Heat Shields?
- Ok, let's clear the air
- S2k v. G35? you do the math
- Hydrolock from CAI?
- twinturbo question?
- Injen or AEM
- which sounds "the best"
- Only 5 ft-lb on MD spacer bolts?
- Gains to expect with these mods?
- Sedan Struts Problems / Sport Pkg
- G35 Warrantee issues - What's broke?
- Popcharger or K&N drop-in?
- REAL VDC mod, perhaps???
- what should i do?!
- On sale now: my new VDC mod!
- New Kinetix Intake Manifold
- KPTechnologies Shift Light
- AAM spacer???
- How to polish the stock plenum?
- Kinetix plenum and engine cover
- Spacer installation question
- G3 CAI Reviews?
- Need advice for some G35 Coupe mods...
- Polished Z tube
- Fluidampr, soon...
- Pullies
- Put stock cats back on, all i can say is WOW
- 3/8" Motordyne Plenum Spacer, Z Tube, and JWT Popcharger recieved and installed!!!
- For people who are getting the SPacer
- Vortech Installers in Dallas/Ft. Worth area?
- Engine cover off = better heat dissipation?
- Speedforce racing Intake Manifold
- Need Advice, Asap!!! Possible Starter Problem!!
- APS Plenum Is Out! GB Too!
- Squealing noise coming from passenger wheel?
- Invidia G200 Exhaust
- Just did my first MOD (Z tube and K&N filter,) next is spacer via the group buy
- Cutting Coupe engine cover to fit around Crawford Plenum
- Anniversary Edition Lower Plenum
- Speaker Stopped Working.
- Where?
- Finding qualified installers
- Keyed Battery Cut Off Switch Install
- 2 HP from Z tube?
- 300????
- squealing UR pulley
- Nismo airbag warning harness..HELP!
- Rogue Engineering Short Shifter
- mildewy smell from vents when ac on!
- My final 'run in' with V6p.net
- clutch vibration when its over 4000rmp..is dat normal?
- DC Headers and ACT/Nismo installed
- hey gord
- Newbie Asks stupid warranty question about modding
- Wideband A/F Gauge
- VDC, Brake, Slip light come on while driving!!!
- Blackstone Reports
- Crank Pulley Installers
- shaky/fluctuating idle after installing the Kinetix Plenum
- Vdc Noise
- How do you add a third power adapter to an '03
- Stillen Hi-flo intake - HELP!
- Anyone had any problems w/ Pulley sets?
- Error Codes P1167 & P1273
- Not your usual break in question
- Noise question...
- Colored Wire Loom
- Need something Chromed?
- Technosquare ECU owners: I have a ?
- Kinetix Hi-Flo cat issues
- NISSAN oil filter??
- crawford plenum, cats, Y-pipe, Z-tube and pop charger
- True Cold Air Intake
- Would this ECU do anything?
- Borla exhaust with headers
- Smaller alarm remote
- How-to install Ground Wire kit?
- G H-Techs / TEIN CS coilovers
- Rear Brakes Clicking Noise
- Sleeved/decked block problem.... going to do engine #4...
- Getting two engines, are they worth it?
- 2005 vehicles responding to mods?
- What is a spacer/plenum?
- Best Intake Upgrade For The G?
- Throttle Body & MAF Sensor Cleaning
- Need help getting 3M silicone lube plus, wet type
- Quick question about Y-pipe
- anyone want to sell me their stillen intake? =)
- STILLEN Hi-Flo intake pic's
- Crawford hi-flow cats, Crawford intake Plenum, UR pulley, Gruppe-s y pipe
- PMI - "Poor Man's Intercooler"
- Manifold Bypass Mod
- Burning Smell in AC Vent!
- Newbie Needs help with OEM Air box
- Is anyone using an oil reservior catch tank?
