PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
  1. Custom engine lower brace
  2. After battery disconnect, sel, vdc, slip on
  3. stillen aluminium/custom reservoir tank
  4. FUEL TANK smell
  5. stillen upgraded intercooler pump
  6. Infiniti Diagnostics or OBD2 software on PC
  7. Vr30ddtt
  8. No start issue
  9. Loud popping under heavy mid/heavy load + sluggish
  10. "miss" at idle
  11. Where can I find these parts (see pics)
  12. Can I use a non rev up short block on my rev up engine?
  13. Oil leaking on AC compressor
  14. Plenum Spacer Question!
  15. G35 fuel filter update
  16. CEL after Spark Plug change (2 codes inside)
  17. Need help
  18. G35 fuel filter
  19. larger injectors
  20. Oil consumtion truth and fix!
  21. Mystery engine bracket
  22. AEM FIC with VQ type 1 ecu
  23. Is my engine blown? (video)
  24. Oversized oil filter
  25. 2004 G35 Coupe Jerks/Jolts out of 1st gear.
  26. G35 fuel pump
  27. Antifreeze in transmission
  28. Fixed P0340 now have P1078
  29. 03 Sedan w/ 06 rev up motor swap QUESTIONS
  30. 07 G35 Shifting weirdly/slipping, too much transmission fluid?
  31. 05 G35 coupe transmission issues
  32. Replaced driver side cam sensor, wont run
  33. 2003 G35 Clutch Recommendation Help
  34. Terrible Gas Mileage!! 13 MPG??!!
  35. P1136 - Intake Valve Timing Control Solenoid Valve Circuit Bank 2
  36. MY fix to P1273 and P1283
  37. loud cracking upon acceleration
  38. Catalytic Converter Removal Help!?
  39. 05 G35 Sedan 105k miles services ( valve cover gasket, tranny fluid..)
  40. Problem with A/C. Any ideas?
  41. New Build daily driver 500 HP
  42. Random Misfire issue - High o2 voltages
  43. Engine light on
  44. Loose green wire engine bay.
  45. TWM short shifter rattle, 2005 6mt g35 coupe
  46. Engine knocking close to firewall
  47. Ticking sound coming from drivers side
  48. 2004 Sedan weird noise
  49. Chatter only at start-up
  50. Radiator upper mounting bracket help
  51. Rear Differential Year-to-Year Compatability?
  52. 03 Overheating at idle
  53. Grinding/hard vibration when engaging reverse?
  54. Trouble starting, Sometimes starts normally, VDC/SLIP Lights On
  55. P0171 need help
  56. The Lightened Drivetrain Debate... Anyone tried this?
  57. G35 coupe question
  58. Won't Rev Past 5k rpm
  59. New Ambient Pressure Catch Can To Fix major Oil Consumption
  60. sluggish 4K+ acceleration, increased fuel consumption.... no codes.
  61. My A/C is making this noise (video inside)
  62. Tuner in MD/Question.
  63. Engine - Oil Consumption
  64. g35 Supercharged engine noise
  65. Valve Cover + VC Gasket replaced = smoke from engine?
  66. G35 engine noises!
  67. APS Twin Turbo kit /Rev up / Manual Transmission
  68. Trying to bleed cooling system.
  69. Injector Ohm specs - my new ones are slightly lower
  70. Engine Ticking
  71. Need Help - Engine Probs
  72. 2004 JDM non-rev 350z 5AT motor into US 2004 G35 coupe 6mt
  73. Is my TB getting stuck at high rpm? 5AT 04 sedan
  74. CD009 transmission? What do you guys think??
  75. Should I install new o2 sensors?
  76. missing at idle and in D, but fine off idle
  77. LS2 intake flange on VK56DE intake?
  78. Air Filter Change --> Check Engine Light???
  79. AT Check light
  80. Is this CAM sensor or Valve Timing Control Solenoid?
  81. Saclam Z33 Exhaust
  82. My g35 coupe
  83. ******. WHO HAS CJM TWIN PUMP??? Help a brotha out!!!!!*****
  84. Nismo HR headers on DE
  85. Rough clutch when shifting at high rpms?
  86. 04 coupe vk56 engine swap and build
  87. Odd WOT issue on 03 5at coupe - no codes tripped
  88. 07 V36 timing chain renewal advice
  89. Isolated? overheating at idle (UPDATE - fixed)
  90. 03 sedan ecu vs all
  91. Electrical problem? PCM issue??
  92. P2A00 & P2A003 Solved!
  93. AC Compresser Idler Pulley.
  94. Camshaft Position sensor
  95. Engine making strange sound- I was wondering if anyone knew what it was
  96. De transmission bellhousing removal
  97. Vehicle speed sensor A P0500
  98. Can you run an ignition coil upside down?
  99. Engine rattle around 2200 RPM
  100. 05 G35 coupe overheating issue?
