- Best place to get pop charger and z-tube combo?
- Innovate! Motorsports - G35 and 350z installation supplements
- Magnetic Oil Drain Plug
- Nismo Cam Installation
- please help - connecting G35c front airbag sensor
- Best Bang for your Buck Mods.
- unichip available for G35 and 350Z
- 350evo Throttle Body Spec Needed..
- Z-tube Horsepower?
- Carbon builded up on tail pipes?
- intake
- Carbon Fiber Engine Cover?!
- most important z-tube alteration!!!
- ???warrenty???
- Can Z-Tube be used with stock airbox?
- G35 PRO Performance Speed Chip Module
- beginning mods
- OEM pad and rotor wear AND dust..suggestion
- Trouble starting?!
- pop charger with an extra pop!
- need ECU Wiring Diagram
- what to do next?
- Unusual sounds from exhaust...
- z-tube, pop charger, and intake
- FS: stock g35 coupe exhaust, intake, and springs
- iNITIAL MOD SUGGESTIONS
- GT Spec's Lower Tie Brace
- EFI Fuse Location
- Service Manual
- New Arrival Items: Chrome/Polish "Z" Intake Tube
- V1 mirror
- Question about engine compression
- Need a belt tensioner gauge to replace drive belt?
- Yellow Exclamation light?
- HELP! Installed injen intake and now car wont start!
- I installed an injen auto intake on my manual and...
- no dispstick
- Tech Article for Intake
- PLEASE HELP, major problem with car
- BCM Program Question
- found new harmonic balanced crank pulley!!!!
- 2005 G35x Mods ???
- NEED HELP: Fuji exhuast please look
- wow, just spent 4 hours tryin to install headlights and got NO where
- Valentine-1 does POP!
- Nismo (Ti vs. GT-Ti) Shift Knobs
- Current TCM version?
- Guage Pod above the AC display
- New Plenum Design
- UR Crank Pulley: The Final Word
- Rogue Shifter Group Buy Ending! ($192)
- Leaving your coupe outside...
- BCM Control Module Customization Chart
- Oil Changes
- The car is READY!!!!! (pics)
- Climate Control Problems - Need Help
- $50 CAI's on Ebay
- Brake Pad and Rotor maintenance?
- White Nismo Guages
- Stillen Hi-Flo cold air intake
- problem with kinetix v4 plenum
- VQ35 Cutaway Picture?
- Attn: All Newbiees
- Cold AIr Intake
- Name of interior part...
- G35 sedan 5at dyno Results
- MTEC and PIAA Lights installed PICS
- ? about engine oil
- Supercharge or Turbo?
- North America G35 Drivers, Please help! How to identify '05 engine from '04?
- CATS DIY? How hard to do?
- Any good shops in NJ? Preferably close to..
- did search but still confused about my injen exhaut rattling after install
- VDC glitch?
- Samco ordering
- 2004 coupe w/ 2005 HP
- Help with the i30t!
- Question About Lifting Coupe
- B&G or BNG oil
- Pulley question please..
- 4 horns
- Digital Clock
- Protective Aftermarket Exterior Parts, That Are NEEDED? (Part 1)
- Odometer Question...
- Will a 350Z engine bolt directly into a G35 Coupe
- PUBLIC APOLOGY
- Best Intake
- problem with door locks
- Bad Scammer #2 - jaerian
- nismo intake
- Latest UOA on Mobil1...
- MAJOR PROBLEM!!!
- Best Short Ram?
- PC/Z Tube Questions
- Best Mods for the $
- BAD SCAMMER
- CAUTION: CA: Read this: onramp smog sniffer
- Anyone put the Coupe Mid and Y Pipes on a Sedan
- The Unichip, Coming soon for the G35/350z
