PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
  1. Z - tube??
  2. Is there a negative to switching to a Z tube?
  3. Greddy E-Manage vs TS Reflash???
  4. Installed Stillen Exhaust on Sedan, it feels slow?
  5. Group BUY for GTECH Pro SS or RR
  6. Kinetix Plenum
  7. Has anyone lowerd a G35X?
  8. Stock Air Box Mod?
  9. Let's Talk Cooling
  10. Need Nismo / Type N Bumper 4 repairs from Crash
  11. Let's Talk Fuel Delivery
  12. Let's Talk Ignition Systems
  13. HP increase: first step ?
  14. Help with Injen SES install
  15. Side Marker Mod & Warranty problem (from FA)
  16. Worth getting the JWT Pop Charger?
  17. Wheel interchangeability
  18. SIDE MIRROR
  19. HATED THE SOUND OF MY NEW Y-PIPE!!!
  20. Just Did K&N + Z-tube-Have Question?
  21. 2005 Coupes will not have memory
  22. Best Drop in filter...?
  23. whats up with APS?
  24. INJEN CAI on ebay...only $100.00 what do you think
  25. Install mods one at a time or all at once?
  26. Detailed UTR Carbon Fiber "Z" Tube Release Info
  27. Question?
  28. NEED OPINION - HP INCREASE W/O TURBO
  29. Installed Crawford V5 Plenum
  30. How to clean jw popcharger
  31. To TS ESU or NOT????
  32. i need a powerduct!!
  33. Breakin
  34. Power Steering Fluid?
  35. Air Intake System Test Results
  36. Carbon Fiber Induction System
  37. APS at SEMA
  38. Technosquare ecu?
  39. Removing the headlights on a G35c
  40. Ticking sound coming from right rear brake/wheel
  41. Stillen Sedan Exhaust Weight?
  42. Alum Pedals 5AT- E brake or Not??
  43. Stillen CAB Install Guide
  44. replacing belt-driven fan on sedan..
  45. Oil Change
  46. Interior LED ambient lighting
  47. my vegas winnings!
  48. crushable copper washer, where to buy?
  49. Carbon Fiber Engine Cover
  50. Check out the stuff Teckademics is putting out
  51. Stock air intake
  52. fuel
  53. Any body know where interior lights fuse is?
  54. Crank engine damage
  55. Putting back on the factory air intake
  56. How much for internals and what do I need? HELP!
  57. Impul ECU
  58. Where to ground Valentine 1?
  59. Need help about oil change
  60. ECU vs. PLENUM... if you can only have one
  61. HELP! Strange Engine Noise
  62. ...G shuts off at 70MPH
  63. synthetic or regular
  64. Mod GOD
  65. installed wires, ztube, and pop charger.reset ecu?
  66. Question about coupe mid-pipe install on a sedan
  67. weight reduction?
  68. Intake Twister???
  69. DIY for Y-pipe
  70. Sport Z Magazine - SoCal Dyno Day Article
  71. Finally finished Header Install
  72. Power that also gets Speed
  73. Aluminum Dash Coating
  74. INSTALLING GAUGES
  75. HELP! Just sold car and can't smog with Injen CAI!
  76. UV city lights & Led markers
  77. Single most powerful mod for under $1,000.
  78. Which air flow to get?
  79. Headlight/Fog Light Fuse FOUND!
  80. Switch Location
  81. Squeaky Brakes at 2700 Miles?
  82. 10w-30 Oil OK in Sou Cal ?
  83. need OEM plenum
  84. Gordgee's Grounding Gear-Impressions
  85. how to diagnose oil consumption??
  86. Removal of console boot facia
  87. TEST PIPE SMELL?...
  88. WHERE TO START
  89. Grinding coming from right front
  90. My car likes the Crawford cats
  91. Thinking of switching my INJEN CAI to Z-TUBE
  92. OBD2 scanners
  93. something weird happened to my coupe..
  94. Windows-Up and Ground wiring
  95. LOUDEST air filter
  96. Stillen SC Warranty "available"
  97. AC gone bad?
  98. chip for G35?
  99. 1st Set of Pro-1 Headers installed!
  100. How much power will I have?
