- 03 G35 transmision questions will any auto transmission fit from 2003 and up?
- Slow Power Steering Fluid Leak
- wot box set up (coil wires)
- VQ35DE Low RPM/High Load Engine Rattle
- Replaced Valve Cover Gaskets Today
- Cleaned Throttle Bodies, Did Reset, Still High Idle 2007 G35x
- Cam timing chain play
- Vq35HR Timing / oil galley gaskets questions
- Rear differential replacement write up
- Replaced Fuel Sending Unit and Fuel pump still faulty fuel gauge
- Speed sensor??? Please help
- Speed sensor?? Please help
- High idle issue
- Multiple Random Misfires * 03 G35 6MT
- Off brand timing chain kit?
- high Idle, P0507
- BHG Repair
- Need Help!
- TRANSMISSION NIGHTMARE CODE P1716 (long read)
- Engine replacement help 2005 g35 coupe 5at
- Engine Noise (Video available)
- 2005 G35 Sedan - Valve problem?
- Rattling noise
- Slight noise, I would describe as whirring or whistling when accelerating hard(ish)
- New g35 owner help!!
- Engine Oil Question
- To the ebay twin turbo buyers
- HELP Unknown troubles with my car
- Upper Oil Pan Leak
- Thermostat leaking
- Fast Crank won't start
- car won't start, rad fans come on when key is "ON"
- G35 overheating on hwy at 80mph
- Burning oil smell
- Strange Intermittent Idle Issue
- Intake Vortech Ti
- FAKE Uprev Protuner alert
- Overheating help
- 06 6mt revving high and won't move from standstill
- Help on cosworth intake o rings!!!
- AT Drain Plug Details
- G35 engine cuts off
- 3.5 Overheats, no cabin heat
- Rattling noise coming from engine bay
- 2005 6MT G35 knocking sound (Video attached) any ideas?
- Extended crank
- Need help choosing Con Rod bearings!
- LS1 CD009 fitment question(Sorry, I'm that guy)
- 2003-2007 infinite g35 starters
- O3 sedan exhaust
- I THINK it might be the throttle body please help!!!
- car accelerates very slowly
- Throttle body troubles (cant get it off)
- Advice on next steps ...
- Coolant flush and AT fluid change
- Low RPM while idling
- Your Trusted shop in Houston tx
- Vq turns off while driving HELP
- Did I trigger the P0340 code?
- 05 sedan g35 strange cam position sensor issue
- HELP!!! Crank no fuel no spark
- starter problem
- rebuild or new motor???
- Balance shafts? do we have them? if so can we remove them?
- Please help need part number 2006 g35 coupe
- AT Check Light ! HELP !
- Tomei LSD with 3:9:1 gears
- O2 Sensor Problem? Code P1273
- 03 g35 vq37 swap ... Not your typical wanna know info thread
- Engine noise G35 HELP! ASAP
- Engine noise upon start up 2004 G35 Coupe Automatic
- Engine swap
- Head gasket oil leak.
- Oil leak
- Engine sucked water
- G37 injectors in a G35
- VQ35DE Manifold Porting
- Holley brand NOS system
- Camshaft Positioning Sensor issues
- Slip light blinks fast at 40 mph + after crankshaft sensor replacement
- Exhaust leak between engine and headers
- 05 g35 cranks but wont start
- New plugs - 4/5 miles before complete stall and no start
- What Is Wrong With My Clutch/Transmission
- Not to sure whats going on.
- '04 6MT not pulling
- Cylinder 1 Misfire
- Help me please I have 2 weeks left to fix my car
- I need help! Please
- Help! My car won't start, crank or nothing
- p1273 and 1283
- Drive and Tiptronic gears are switched. need help
- need help 1400 miles from home might have a bad ecu? anyne seen this problem before?
- Considering an engine build. What should I do?
- VQ35DE Revup rebuild. help me.
- 04 5at Weird Unplugged cable and oil leak.
- Storing the G, fuel stabilizer ?
- 04' G35 Sedan random misfires.
- Very low idle
