View Full Version : Engine, Drivetrain & Forced-Induction
  1. Howling noise coming from front of the car
  2. Basic Modding Dictionary (noob)
  3. exhaust feed back
  4. stock looking for upgrades
  5. Time to change fluids!
  6. my drive back to NY
  7. ebay pulley set
  8. Oil Coolers
  9. Shipping exhaust
  10. Thermostat Replacement
  11. bad gas mileage
  12. Rack & Pinion still leaking after repair?
  13. rough idle at star up..
  14. Mishimoto Thermostat?
  15. Weekend from Hell
  16. Car wont come out of park.....HELP ASAP
  17. 5AT + transgo + gears+ grounding wires+ nitrous= win?
  18. AT CHECK LIGHT! help
  19. Rebuild VQ35 Rev Up?
  20. Timing Chain (I think) Rattle lasts for a good 5-6 Minutes Need Help!
  21. what is the diference. trasmission 2003 and the 2007
  22. Tach not sweeping smooth...buying a G35
  23. Ignition msd-hks???
  24. Clutch and Transmission Gurus please assist
  25. COBB Tuning's Forced Induction VQ Project!
  26. my car is OVER HEAT
  27. Tune up...
  28. Car won't start, any ideas?
  29. Exhaust leak.. Am i loosing power?
  30. Weird Problem
  31. car shuts off fuel pump before tank is full?
  32. 350evo still in business?
  33. what can be causing this throttle problem /loss of power
  34. oil consumption problem 04 automatic
  35. Porting and Polishing your Cylander Heads?
  36. just put the rev up swap in my non rev 03 but need help..o2 sensors
  37. N/a build cost V FI
  38. P1283 & o2 sensor question
  39. Help replacing front oxygen sensor
  40. Stage 3 Stillen?
  41. performance chip?
  42. Top End Power
  43. Mishimoto radiator
  44. vortech s/c intercooler upgrade feeler.
  45. Mishimoto radiator - problem with lower hose
  46. p1281
  47. Transmission went out, thinking about an RB26
  48. Grinding 3rd and not the good kind
  49. Tunning Stages, Please Help
  50. VQ37VHR first gen G35?
  51. rubbing noise passenger rear ?
  52. A/C Makes Noise When Turning On
  53. I took my car in for oil consumption test.. grrr.
  54. Engine knocks after oil change, please help!!!
  55. Weird issues.....
  56. where to buy thermal isolating lower plenum to intake manifold gasket?
  57. Need help!?!?!?!?!
  58. Injector Upgrade
  59. Highest all motor numbers on driver???????
  60. Silly Question about MD Copper iso thermal spacer
  61. Fluids
  62. Loud rumbling metal noise?
  63. Throwing Code PO345
  64. Throttle Body Coolant Bypass mod?
  65. Problem with power
  66. 2006 G35 Coupe with Service Engine Light
  67. Air leak?
  68. all of a sudden car runs like total ****
  69. Tranny & diff fluids????
  70. radiator spewing out
  71. Gears 1-4 shift fine but when I get to 5th it's like I'm in neutral... :(
  72. engine harness while engine in car?
  73. any differance in brands of injectors?
  74. VALVE COVERS RTV or NO RTV???
  75. Want to add 3.67 gears just for the strip? Here ya go
  76. Oil overfill... Fvcking mechanic....
  77. Clutch ticking noise
  78. want to make 20+ hp
  79. Check those PCV valves
  80. vq30de heads
  81. Oil usage on a non-rev up 03 VQ35. Weight choice on the next change?
  82. oil leak!
  83. Motor stubles and dies at Idle
  84. My exhaust is resting on my M-Brace.. is this bad?
  85. Grinding at highway speeds
  86. Bad Vibration!! Help!!
  87. Oil Pressure Light
  88. CAM Sensor Replace 05 G35 Sedan
  89. Need advice on engine problem
  90. Lack of performance?
  91. Some sort of switch for Exhaust ???
  92. PCD Performance Chip, Worth it??
  93. Built n/a motor and oil consumption
  94. 2006 G35 Coupe 6MT Noises
  95. 350hp
  96. Titanium Bolt Upgrade! Big Ballers in the House!
  97. Does having the CEL on bog down the engine?
  98. TopSpeed Pro-1 Exhaust: Installation & Review ( with pictures )
  99. 2 Nissan Data Scan II users
  100. Ecu chip
