- WTB: 4.08 or 3.9 final drive
- FS: Competition Twin Disk Clutch (Only 4k miles)
- FS: CD009 + OEM Clutch (only 27k miles)
- FS Canada: Passenger axle stub from 6mt diff - Needed to upgrade a 5AT differential
- FS: ACT Clutch and Flywheel
- WTB: Flywheel
- WTB: 06 G35X front passenger side axle
- WTT: 3.3VLSD for 3.5VLSD
- FS: Carbonetics 1.5 LSD 3.5FD installed in pumpkin
- FS: 6mt 03-07 Z1 G35 Platinum Series Aluminum 1-Piece Driveshaft
- WTB: CD009 6MT + Drive Shaft
- FS: JWT Lightweight Clutch Setup (CHEAP!)
- FS: OEM G35 Flywheel 40k miles CHEAP
- FS SoCal: ACT clutch and JWT flywheel
- WTB: 04 G35 coupe auto trans
- WTB: LSD, Twin Disk Clutch,
- FS: Competition Stage 2 Clutch
- WTB: flywheel for 04 coupe
- FS NorEast: Stock Clutch
- FS SoCal: Brand New ACT clutch
- WTB: Spec Clutch ss
- FS: NGK Iridium IX SPark Plugs (8)
- FS: JWT Flywheel for G35 VQ35DE
- FS: B&M Short Throw Shifter
- FS NorEast: Clutch Bracket & Hardware off g35 Coupe RevUp
- WTB: Transmission oil cooler for 5AT
- FS NorCal: G37 vlsd rear differential 3.69 fd
- FS: JWT clutch and flywheel
- FS SoCal: Differential: 3.3 VLSD
- FS: Competition Twin Disc clutch
- FS: RedLine Transmission Fluid MT-85 (1QT)
- WTB NorCal: Need OEM Clutch set
- FS: Carbonetic Twin Clutch Kit with Flywheel
- WTB: exedy OEM clutch kit
- FS: 2006 G35 Coupe Clutch & Flywheel
- FS: Jwt clutch and flywheel and Fidanza flywheel 03-06
- FS: Act Streetlite Flywheel
- FS: 2008 VQ35HR 350z OEM Clutch & Flywheel w/35k miles
- FS: 2008 OEM 350z VLSD w/3.5FD w/35k miles
- FS: 3.3 VLSD Diff
- FS: Stillen Engine Damper Brace -New in Box
- FS SoCal: Auto Transmission and OEM drive shaft
- WTB SoCal: 2005 AT valve body assembly
- FS: CD009 and F1 clutch/FW
- WTB: ANY 6 speed
- FS: Lightweight AASCO/JWT/Stillen Flywheel
- WTB: OEM Flywheel
- FS NorCal: *Brand New In Box Exedy OEM Clutch Kit and ACT Streetlite Flywheel* PICS INSIDE.
- FS: OEM transmission pan
- FS: Stock OEM 6MT shifter
- WTB SoEast: CD-009 Manual Transmission
- FS NorEast: Sikky 350Z/G35 Wilood Master Cylinder Conversion Kit
- FS: OS Giken Superlock LSD
- FS: OS Giken STR twin disc clutch
- WTB: OEM Clutch and pressure plate
- FS: HD-2 valvebody upgrade
- WTB: Tripple disk
- FS SoEast: 4.083 Final drive Vlsd pumpkin & 3.35 VLSD pumpkin
- FS Texas: RJM Clutch Pedal & Oem Aluminum Pedals 6MT
- FS: ORC Ogura Racing Clutch (NIB)
- FS NorCal: 3.69 fd vlsd
- WTB: front right axle for 04 g35x
- FS: OS Giken Twin Plate Clutch used for 4000miles
- FS SoEast: G35 OEM shifter
- FS: 5AT Trans, Interior, 6mt swap parts and other goodies.
- WTB: Twin Disc Clutch
- FS: 03.5 5AT transmission. LEVEL10 Rebuild kit
- FS SoCal: G35 350Z automatic transmission w/Transgo shift kit
- WTB: TWM Performance Short Shifter
- FS: 3.3 (non-LSD) pumpkin off 06 g35 coupe
- FS: RJM Performance A.F.P Clutch Pedal System
- FS: B&M Short Shifter
- FS: Complete 3.3 non-locking differential
- FS: Complete 3.5 VLSD differential
- FS Texas: SGP Solid Motor Mounts & OEM '04 G35 Clutch/Flywheel
- FS: rear dif brace V2
- FS NorEast: auto 05 coupe lsd 3.3fd pumpkin
- FS: Clutch Pedal Assist Spring for 6MT
- WTB: Rogue Short Shifter
- FS: 04 infiniti g35 6mt tranny,driveshaft,etc
- WTB: OEM Flywheel
- FS: Spec clutch & act prolite flywheel & oem clutch & flyewheel
- FS: 4,083 FD, cusco RS lsd pumpkin and more
- FS: OEM clutch master cylinder 30610-CD00B
- FS: Dss pro axles
- WTB: 2003 G35 Sedan AT transmission
- WTB: LSD for RWD Sedan
- WTB: Stillen or TWM short shifter
- FS: Stock Clutch, Flywheel, and random stuff.
- FS: Short shifter ? Stock clutch and flywheel
- WTB: 3.3vlsd
- FS NorEast: 2005 5AT and 3.3VLSD
- FS: Transgo VB kit A/T
- WTB: driveshaft
- WTB: Lightweight Flywheel.
- WTB: 350z/G35 BASE OPEN DIFF AXLE STUBS
- WTB: Rogue Engineering Short Shifter Kit
- FS: OEM Infiniti G35/Nissan 350Z Clutch Slave Cylinder
- WTB: VLSD axle shafts
