- Coupe stock tweeter mounting depth
- lacking midbass from my components
- Sneak Peak - Fiberglass Enclosure
- which blank or pocket for dbl din
- Alpine iPersonalize, tweaking info
- scosche NDAB antenna adapter
- Audio install question/opinions
- Newbie with some questions :-\
- The Audio Overhaul is DONE!
- Ipod Interface
- Plug-in replacement for Clarion OEM XM radio?
- My AVIC-N1 double-din conversion
- CD Up Side Down
- Rear of the Bose Headunit has plug for antenna?
- how to determine wut + or - is on speaker wire
- Anyone else thinks rear speakers = just fill?
- Ipod & Aux Connector
- CD error F0
- HU - Does this make sense?
- VISOR MONITORS
- where to put jl grounding lug?
- My car audio upgrade story! & Questions
- SEDAN BOSE UPGRADE TO 222 WATTS?
- Custom dash version II
- Aux input?
- Rear Ashtray Alternative...
- Question about the Eclipes AVN 2454
- Bose Audio Worth the Upgrade?
- Highest Quality Gauges? What brands do you like?
- I found the solution for my Alpine MP3 Changer!!
- Alpine 6.5"typeR installed!
- Pioneer AVIC-N1 good?
- PTY?
- WantedFactory NAVto play DVD's in NJ or NY without
- air bag indicator
- Ps2 install in upper glove box
- finally got my 2 HX2's need box
- What length for Power cable to battery?
- Pictures of my Navone LOC
- running 2guage power wire from bat thru firewall
- Speaker Depth for replacements in OEM spots?
- Bose Front Ohm
- PICS - Coupe Rear panels and BOSE 6x9 removal DIY
- my battery voltage is below 10 volts :(
- RBC Install - Ashtray Question
- sat radio
- WTB stock radio
- Stereo & MP3s
- my jl 300/4 amp isnt turning on
- Power Cap Question
- Door Panel Rattle?
- Anyone with DEX-P9 and DEQ-P9???
- The definitive PAC Sat AUX IPod Thread
- Wiring Diagram for Sedan w/Bose
- I ordered a Navone LOC/Dynamat Questions
- dynamat extreme question
- Installed a sub, FM reception went south
- PAC aux unit
- Move Nav DVD Rom to Trunk?
- Navigation System
- where is the factory ground wire located?
- Does Sedan rear doors use 5.25 or 6.5?
- Install Ripoff?? I might DIM...
- Do I have RDS?
- question about components speakers
- NAV Help
- a/c question with aftermarket headunit
- Back Up Sonar?
- Anyone installed a DEI-555U Transponder Bypass?
- Anyone installed a PAC SWI-X?
- 4 Channel LOC, but what about sub?
- Stock Head Unit / Amplifier
- How to install Homelink mirror on G
- PYLE Amp?
- Line driver for stock hu?
- ALPINE VS PIONEER
- speaker pops when i turn on my aftermarket headuni
- AFTER MARKET NAVI HELP
- Any DEI Viper Dealers here?
- eclipse avx2494
- Another Bose Upgrade
- IPOD Install via SAT in Trunk???
- scoche NN03B harness wiring question
- Adding powered sub to base stereo
- Dell DJ...alternative to iPod
- Audio Q RE:Stock HU
- navigation DVD copy
- Bose amp upgraded by Infiniti?
- Eclipse AVN2454 Install PICs /video
- Double din AC Controller...WHY?
- Sub in the trunk
- 2004 Sedan non bose stereo questions
- Navigation Question. (Aftermarket vs. Stock)
- PICS - G35 Coupe Adding AMPS & EQ BOSE DIY
- AV Electronics Question/Problem
- Nav System
- Dealer SAT Install $695.00? Say Wha!!
- aftermarket 6x9's a direct fit?
- Eclipse AVN install
- Video On/Off switch DIY?
