- Hks HI power
- Carbon Fiber Z-Tube
- Will the tanabe medallion rear section for sedan fit a stock midpipe
- Can A Rev-Up Coupe 6MT w/ Bolt-Ons Take an IS350 Off all Speeds?
- is this a 5/16 md spacer or something different?
- z tube help!!! asap!!
- Best Intake and Exhaust?
- need help with exhaust
- OEM Intake Mods
- DIY: More Air to JWT Pop Charger
- anyone have hardware for the 5/16 basic plenum spacer?
- I need a quieter rear section for my sedan, any suggestions
- advice please!
- new kinetix manifold...???
- Do any of our vendors sell throttle body spacer?
- Megan Racing Headers
- VQ from m35 gains Hp with FUJITA (12hp?)
- does Dynamat or B-quiet help in reducing drone?
- Nismo SRI (fabricated) -vs- OEM ZTube
- injen exhuast too loud!
- throttle body: Coolant Bypass mod
- Need Opinions?
- HFC's I need a push!!!!!
- SES light with FI HFC's???
- The Equivalent?
- Nismo exhaust + hfc = rasp?
- Need a lil intake HELP
- Intake filter for 08 G35 Sedan question
- Nismo CAI to Short Ram Possible???
- kinetix v+/ MD5/16 spacer combo ..
- Nismo Extension pipe..
- Injen cold air intake or short ram z-tube?
- Added Fast Intentions HFCs....
- What plenum should i go with?
- Any real HP or torque increase from K&N drop-in filter?
- Warranty with N/A Mods
- Reducing Drone
- P1283 still on with nonfoulers
- HFC's install
- Kinetix HFC install
- Is there a fast intentions knock-off??
- HKS Hi Power and Motordyne 5/16 spacer
- Greddy Evo2 or Nismo exhaust?
- has anyone dynoed the blox spacer?
- Please ID and Suggest...
- Will It fit?
- k&n filter
- UR Crank Pulley= no audio system?
- Installed MD 5/16" copper iso - impressions.
- poop charger question
- Experimenting with my exhaust....
- Is this a custom intake or what? ive never seen it before helpp
- Which N1 exhaust is the best?
- Next mod...
- Cold Air Intakes
- Single out 3 inch stainless exhaust
- GOOD NEWS::FI Carbon Fiber Exhaust::G35 Coupe::
- new gasket for headers?
- Fujita intake problems??
- is an ecu flash nessecary if you have intake + spacer?
- top speed pro n1 exhaust
- exhaust/y pipe diameter question
- OBX y pipe
- Removing Muffler
- Need Advice, Centre Muffler Delete
- Will Injen CAI/SES 1986c exhaust for 350z fit G35?
- question
- R2c cai?
- Wideband sensor
- January 1st 2009 HFC'S will be Illegal to sell in California!
- [Need Help] Buying Exhaust/Intake
- what are good mufflers to use on a custom exhaust?
- should i trade my stillen y pipe for an 08hr y pipe?
- anyone ported the stock intake manifold.
- what other brands make crank pulley other than UR?
- what brand used headers should i go with?
- List of single exit exhausts?
- Damaged or Not?
- TOMEI Announces EXPREME VQ35DE Exhaust Manifold Version 2
- What type of exhaust sounds good on first gen G35?
- Blown Stillen HFC
- just installed injen cai. question.
- Anyone familiar with these guys - Plenum Spacer
- Just A Quick Q About Exhaust's ?? Plz Help
- Zerd long tube headers
- JVT headers??
- APEXi NEO INSTALL?
- FI Exhaust
- Rev-Up airbox on a VQ35DE - special note
- Exhaust Diameter
- Exhaust question
- CAI to Short Ram Intake - ECU Reset Needed?
- Fast Intentions Exhaust sitting too low??
- Just ordered my Fast Intentions Exhaust and TP's
- Intense power res test pipes
- any ideas how to make the sound a bit quietly???.
- should i remove the heatshield if i install HFC
- difference between the revised and the pld version of kinetix HFC
- Should I be concerned about crack in catalytic converter?
- Quiet exhaust?
