- 03 Gsedan AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE P1716
- 05 G35x with Auto Transmission Problem - Slipping?
- need a new clutch?
- *** correct way or fill 6-speed trans w/ gear oil ****
- Nismatic J now X?
- Is the 6speed g clutch the same as the 350z?
- Clutch Slipping??
- 2003-2006 5AT vs 2007-2008
- Carbonetics LSD review (Auto G35)
- Exedy Clutch + ACT Flywheel Question
- Rear diff fluid and amount?
- 4.083 F.I Question
- Drop from 4.08 to 3.3 possible?
- Occasional grinding shifting into 5th gear, warranty up later this year..
- Help Needed Please 5 speed auto gearbox
- Transgo VB Upgrade NOT for 5AT Daily Drivers
- Suggestions for replacing friction plate on JWT Flywheel
- 2004 g35 coupe 6mt gear oil is leaking and burning on my y pipe
- Time for a new Clutch
- VLSD or Open Diff
- Manual swap to auto tranny ??
- ATF color with 70k
- Nismo LSD
- Experience with built autos?
- 5AT 3rd gear question.
- Weird Electronic/mechanical humming when clutch is pressed down on while warming up
- ACT Clutch/Flywheel Install Question
- Redline Transmission Fluid - NEW Product
- Anyone have an OEM wheel bearing sitting around?
- Clutch, transmission, flywheel, or bearings?
- Bad clutch or tranny?
- Want to drop from 3.69 to 3.3 FD {{FLAME SUIT ON}}
- 5AT valve body compatability?
- Trasmission Grinding
- Paddle Shifters for G35 03 ?
- Why you should change you Differential Oil at 30K miles
- Transmission problem??
- Question about 3rd gear
- Another Final drive question. 3.5 to 3.7?
- Dealer says they will use Matic J for tranny flush
- VLSD or open dif
- G35X Speed vs. RPM
- Start Up...weird i think?
- AWD Question
- Clutch opinions
- 6MT Burning Smell
- Tranny/Torque converter problems??
- Grinding into reverse?
- Weird problem today with transmission
- Slip light delete
- High Clutch Engagement...
- valve cover/gasket
- Transgo shift kit - 15% off
- wheel bearings need to be pressed?
- Trans Leak 04 6MT?
- Changed Clutch and Flywheel and having problems
- Weird Clutch Pedal issue...
- Help with a front left hub and bearing.
- Rev-up on Auto Tranny?
- Anyone replace clutch and keep flywheel?
- humming noise from my diff
- Help, just had Exedy Stage 1 & JWT flywheel installed…chatter
- 2003-2000 G35 6MT tranny vs 06-07.
- clutch diagnose. What do I need to fix? I need as many opinions as possible!!
- New exhaust is installed and the car is running 4th gear most of the time
- Clutch / Transmission Removal Question
- 5AT slow to engage in drive
- Plenty of oil but oil light is on
- Tranny Fluid
- Drivetrain Fluid Questions....
- 5th gear grinding once after start up?
- DIY SPL front/rear differential bushings
- What clutch to get??
- If you have a 5AT look here
- Anyone ever done CV shafts on an AWD?
- Flush before Transgo?
- Clutch adjustment.
- Engine Swap.. AT/MT Question.
- Humming noise from the rear end
- A/T transmission fluid change
- DIY: Differential Fluid Change
- Its time for 3.5 or 3.6 rear gearing !!!
- I haven't changed my tranny fluid for over 30k miles, what brand/type. please read
- Reverse gear
- 6MT Shifter KICK BACK JIGGLING
- Magnefine Transmission Filter
- rear wheel spinning when clutch disengaged.
- g35 + 4.08 gears + ???? vb upgrade ????
- G35 Coupe Cold Start Jerk??? From Park to Rear
- Shifter shaking under acceleration
- crankshaft position sensor question
- Replacing Clutch Help
- Strange Click Thud Noise After Changing Clutch. Help!!
- Need to replace Valve Body or Trani
- Shifting from 1st to 2nd gear in 04 6mt
- Differential leaking and smoking
- Screeching noise when accelerating after pushing in the clutch?!?
- Wierd Fluid from Rear Diff Area...need help identifying....
- transmission issues...again! Anyone else with this issue
- MT kills itself during a coast to downshift...?!?!
