PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. Switch from auto trans to manual?
  2. will a 08 350z diff , fit my sedan ???
  3. Unorthodox Racing Pulley - Crank???
  4. What Differentials Gears that fit A/T G35 coupe
  5. My Automatic car :(
  6. Trans kit or reprogram?
  7. Edge racing high stall Torque converter!!!!!!
  8. Think I have a fuel problem
  9. Automatic Tranny Flush / Fluids
  10. Differential inspection
  11. will a oem flywheel and pressure plate fit a act clutch??
  12. Tranny Cooler- In line or By-pass?
  13. Complete clutch failure
  14. Tranny Rebuild anyone, anyone? Bueller?
  15. Clutch fix spring removal mod diy complete!
  16. Timken or OES genuine wheel hub assembly
  17. Possible Slave Cylinder Noise....
  18. need new tranny for a 2006 g35 coupe 6mt
  19. Need part # for 2003 G35 valvebody assembly
  20. Bad Clutch Please Help!
  21. Valve body or TCM?
  22. Valve body or TCM?
  23. First gear hard to find.
  24. '04 G35x - Gear Indicator blank
  25. Clutch engagement too low!
  26. RPS Clutch question
  27. Exedy stage 1 with stock flywheel on 2005 coupe 6mt
  28. 03 G35 Auto Trans Free Rev?
  29. need help with flywheel...
  30. Not Shifting!!!
  31. DIY Clutch master cylinder replacement
  32. wheel bearing issue?
  33. 2006 5AT Coupe Rough Shifting??
  34. quick question!!! please take a look :)
  35. Midshaft/Center Support Bearing Noise?
  36. Which Diff for 5AT 3.3 Gears?
  37. Knocking noise?
  38. ugent help, replacing coolant fan
  39. Need Help on Gear ratios on G35x.(Thinking about doing gears)
  40. Auto Trans Fluid Check
  41. Auto Trans Clunk
  42. Help with my 6mt
  43. ACT HDSS + ACT Streetlite Flywheel Questions..
  44. nismo or southbend flywheels
  45. DIY: Stainless steel clutch line
  46. torque specification
  47. Clicking clanking sound coming out of first
  48. DIY 6MT Swap?
  49. Doing first AT fluid change Monday.
  50. Are the flywheel bolts torque to yield bolts?
  51. Experience with Aftermarket Flywheels- Please help
  52. Clutch rattling-Help!
  53. Decipering OBD2 scanner live data feed
  54. JWT vs ACT for Clutch flywheel combo. which is better?
  55. 07 coupe clutch replacement... need last min advice..
  56. sedan 6speed engine
  57. Gear Ratios Explained
  58. Odd shifting in Manumatic mode
  59. performance clutches
  60. tranny issue...automatic 07
  61. Rear Wheel Hub, Options?
  62. New fly wheel?????
  63. DIY: 5AT to 6MT SWAP.
  64. High Stall Converters and 60's
  65. Need advice on where to go to have a new clutch installed.
  66. *** Any help?? Need torque specs for tranny...***
  67. Please help
  68. *** Need new clutch on my 06 FI g35***
  69. VDC Issues? Someone help!
  70. Camshaft position sensor (location?)
  71. clutch slipping?
  72. 07 6mt clunking
  73. Rear Axles...Are the interchangeable?
  74. better clutch
  75. Unusal rattle
  76. how to check to see if my A.C compressor works, please read
  77. new clutch engages off the floor
  78. weird grinding noise
  79. 2004 G35 Stuck in Manual Mode/Neutral
  80. 3.5 VLSD Swap
  81. axle boots
  82. help me convince my dad..a full AT Flush will not adversely affect the AT
  83. Why is my G burning white smoke past 4.5k rpms?
  84. Manual Mode will not engage.
  85. On what vehicles were the VLSD pumpkins?
  86. Throttle Pedal Position Sensor
  87. Stage 2 Clutch Replace 03 MT
  88. Vibration at 40 mph
  89. DIff Oil
  90. thoughts ON JWT clutch and flywheel combo
  91. VERY weird issues
  92. replacing clutch. is this reasonable? $$$
  93. clutch problem? help, engine revs when i get on the gas
  94. Problem with Flywheel timing...
  95. Transgo ftw!
  96. WTB Transgo Kit '03 G35 Sedan AT
  97. Transmission Parts
  98. Click from rear end with momentum change?
  99. Single-Mass flywheel
  100. Valve Body Swap
