- Transmission problem - I think my auto tranny is TOAST!
- Clutch pedal issues.
- Stock clutch w/ aftermarket flywheel
- Question for Valve bodied guys
- Diff Swap question for you gurus
- Clutch opinion
- D/E-Drive Throttle Controller?
- New Release Bearing for Racing Clutch
- Clutch Delay Spring Removal
- Limited slip differential...
- Anyone know a shop willing to install TRANSGO in CNJ
- I just want to replace my clutch
- Another happy Transgo customer...3rd gear goes CHHAAA
- 5th gear hesitation/vibration - problem or characteristic?
- Steering boot grease
- Chirping clutch noise, odd
- Help! A truly unusual noise (even for a G35 transmission)
- Sticky Clutch Dealer says clutch is shot at 34.5k miles
- Just had warranty replacement on tranny, so did clutch..
- 6mt trouble...
- RPS Clutch & Flywheel
- Drive Shaft Lock Nut Question
- 2006 6MT tranny for my project or no?
- Closest to Stock Flywheel and Clutch
- Loose Bolt on Rear Axle
- Changed Man trans fluid NOW have issues
- Matic D in my 5AT?
- Rear Subframe Fluid Leak
- OEM 3.5 Open Diff??
- Engine revs each time I change gears
- A little grinding noise taking off in first gear
- Jerk when car is cold
- ACT or JWT clutch and flywheel for FI?
- Exedy OEM clutch and ACT flywheel
- ATF : This is the right stuff for an 05 G right?!
- Diff fluid changed
- clutch pedal sticking to the floor after i changed the clutch out..
- Carbonetic LSD fluid
- Short Shifters!
- Have you checked your rear axle fluid-LATELY
- CLutch break in period?
- 4.083 gears???
- 6MT Clutch Replacement Options
- clutch pivot ball failure rate on CD009
- 6MT Rebuild Kit
- HELP: Jwt clutch alignment tool?!?
- Shift knob problem!!! help plz....
- OEM Pivot bearing w/ performance clutch replacement?
- im hurting plz help
- clutch switch not working?
- Clutch/Flywheel problem
- Factory flywheel w/ aftermarket clutch
- JWT Heavy Duty Clutch
- Need a New Clutch... Any Suggestions?
- Newbie w/ a project car. clanking noise when shifting. please help!!
- could this work
- some issues with my 07 6speed
- AWD Maintainance
- clutch engaugement changes and some time is soft
- Is this possible?
- Shifting from 1st to 4th during curising speeds
- Replace Clutch Now?
- DE/HR clutch interchangability
- My review the 3.5 VLSD swap into a 5AT
- shifter re-alignment
- 5AT questions
- Edge Racing Torque Converter
- 5th 6th and reverse problem help plz
- whats the most hp/tq you pushed before stock clutch slipping?
- new mlj diff cover
- DIY - Transgo VB Kit
- 05 G35 6MT Clutch problem
- 6MT getting harder to push into gear. Hlp
- Clutch pedal problem
- G37x Manual Conversion
- For those that have swapped VLSD pumpkins
- rough shifting 5AT recently
- Problems sticking gears
- Clutch/flywheel installation price
- Clutch noise/feedback, questions. (Not the flywheel issue)
- Sprung Vs. Unsprung
- Changing ATF fluid
- 03 5AT coupe.. S matic or J matic fluid?
- Letting foot off of gas pedal
- F1 Stage 3,2,&1 Clutch Kits with Steel Flywheel?
- JWT HD Clutch & Flywheel Combo for a 2006 Infiniti G35
- differential oil change
- Who makes OEM clutch and flywheels?
- P1764 Manufacturer Control Transmission
- Switch gears without clutch normal?
- Can't get transmission back in
- How bad is it to ride in manu-matic?
- Tranny/Gear Box Question
- 04 5at rear diff
- syncro?
- 3.3 to 3.7 question
- Just out of curiosity: Super Tech ATF?
- VDC and Slip Problem
- tranny slipping
- Clutch Noises
