- Valve Body Upgrades / Shiftkits
- possible bad throw out bearing and shop mistake?
- Another Clutch Problem
- Clutch sticking in 06 G35
- 2006 Coupe base has 3.3 or 3.5 FD??
- Nissan extroid 8spd cvt transmission
- Yes, another "Help me diagnose this RATTLE" thread
- 5AT Transmission stall and Service Engine Soon light...
- increasing the stall RPM on 5AT
- Quick question need help
- Clutch problem?
- clutch pedal click when releasing pedal
- AT fluid change and ramps
- Is this the imfamous axle click?
- Looking to upgrade clutch and new gears. Any recommendations?
- 5th Gear Lockup on AT?
- 04 AT trans fluid change!
- clicking noise in the rear when i accelerate and decelerate
- Automatic Transmission stuttering
- Aftermarket clutch line question
- OS Giken triple-plate pain
- Getting a higher top speed...
- Rear diff oil for a 5AT
- Installed F1 Racing Stage 1 clutch and flywheel combo
- Changed differential oil at 43000; a waste?
- Popping when stopping????
- 03AT Changing Final Drive
- Vr38dett
- Clutch Pedal Squeak
- clutch feel not consistant?
- Changed ATF and Rear end fluid
- 5AT 3rd gear/top end is just sadly horrendous.
- ***ATTENTION ALL 5AT Drivers wanting to get the Transgo Kit Installed***
- Do I have to worry about breaking a gear
- What's the best price of auto tranny oil?
- Mixing gear oil brands
- Matic-S prices
- Manual tranny, shifter shaking
- QUAIFE 6-Speed Sequential!
- Clutch issue (master/slave cylinder?)
- Does Nismo make the "strong" clutch fork pivot for G35/G35 yet?
- 07 350z clutch+flywheel in 03 g35
- universal joints?
- Old rear diff fluid
- JWT Aftermarket Clutch/Flywheel slight raspy noise
- 2007 350Z 3.69 differential applicability
- Transmission Spacers from GTM
- Quaife ATB Rear Differential.
- help with rear end noise?
- Which bolts to use?
- Anyone used anything other than Matic J or S?
- Any advice? I can't downshift into 3rd or 4th.
- AUTOMATIC with 3.5 DIFF WORTH IT????
- Too late to install a Transgo kit?
- Tranny trouble
- clutch!!
- What to do when rebuilding tranny
- Odd clutch pedal behavior
- should U-joints on the driveshaft get replace
- 6MT Tranny Shake, New Mount?
- Is this a good setup??
- Tranny/flywheel? Plm??
- No more Traction Control!!
- 6MT clunk when letting off gas???
- clutch or tranny problem help needed please
- tranny help please
- Need to find a good transmission shop ?
- Looking to buy 04' G but Tranny Grinds (New Clutch)
- which clutch guys??
- 5&6th acting up
- Removing center panel
- rear axle click
- Tranny Problem...help me diagnose
- Clutch not releasing in higher gears - '04 6MT
- Final Drive Question
- How many miles on JWT cutch do you have.
- 5at trans upgrade
- ACT clutch installed. Car wont start :[
- High Pitch Noise?
- Where to find the transmission assembly part number?
- Possible Tranny Issue
- clutch question
- rumbling noise 6MT help!
- What trannys can fit in my 03 coupe?!
- Stuck in 4th gear?
- JWT Clutch installed / Drive Shaft U-Joints seized
- g35x cv joint busted...ghetto fix question
- Automatic Transmission expert please...
- Automatic Transmission: Drain & Refill vs Flush
- Auto tranny. How much power will it hold?
- What is tihs stuff coming from my pumpkin?
- hydraulic bushing on differential,
- Chunks in tranny or differntials
- 05 GCoupe MT Transmission Question
- Shifting Question
- Question about Transmission Flush & other Maintenence
- Transmission Flush and Sticky Shifting
- 2005 GCoupe MT-Gear Lube
- Tranny Number 2
