- Car Was Sitting For 2 Months And 5 Days, Drove It & The Clutch Seemed Sticky, Normal?
- clutch and knob
- differential clunk when releasing clutch
- Automatic Manual Mode
- Weird tranny issue!!
- A/C clutch disc plate... where can I get one??
- Dealer cost to replace clutch?
- Turning off/disabling VDC (For real.)
- damaged clutch??
- Clutch upgrade. I need help
- Shift Fork Pivot bolt....$12 bolt=$1300 clutch...
- 4.083 Gears/Final Drive
- JWT clutch and flywheel
- clutch clicking
- Squeaking Clutch?
- Clutch slipping????
- Final Drive Gear Ratio 4.9?
- Transmission Flush Qs
- is there a faulty 03 tranny issue?
- Clutch Slave Cylinder- need to replace?
- Missing gear and redlining?
- Clutch Sound
- Transmission trouble
- anyone know a good job for a clutch install in socal???
- 04 5AT transmission fluid change?
- LSD for 5 AT sedan.
- quietest clutch/flywheel combo's ??
- Any one in NJ area?? JWT clutch ?
- Help!! Clutch pressure ??
- New clutch.. Nismo?
- ABS, VDC Off, Slip light all ON
- rear noise...
- Need a clutch job in Boston, MA! Help!!
- 03 auto tranny ?
- 2006 A/t Tranny Problems
- 04 G35 6 spd tranny fluid
- parking the car in gear
- Need some help, clutch is slipping.
- rear differential
- Gear Oil, gear lubricant, cluth fluid??
- transmission coolers
- Clutch or release bearing issue?
- question about shifting on 03 sedan AT
- Weird clutch feeling?
- Manual Tranny Fluid & Differential Fluid?
- Clutch fluid
- best auto tranny cooler??
- Weird issue with SGP built 5AT trans...Have some questions
- need help w/ clutch b4 going to dealership PLZ!
- questions about 2004 g35 clutch
- transmission fluid
- Clutch Trouble?
- 05 AT shift lag
- Which clutch and flywheel ACT of JWT???
- Looking for A/C clutch disc bolt
- Car shifting like crap
- Stage 3 Xtd Or F1 clutch With Lite Flywheel
- Tranny swap?
- Tranny swap?
- stock flywheel
- Help.
- 5 different valve bodies?
- oem clutch kit
- F1 prolite flywheel
- neutral sensor
- Recommendations on new clutch and flywheel
- What Amsoil fluid to use in Tranny and Diff??
- Clutch burning???
- Clutch height adjustment
- 5AT gear ratio options?
- Who makes built transmissions?
- Does a manual transmission have a TCM?
- Can a clutch get burned in a day
- Stock Clutch weak?
- MY DIY differential oil change
- opinion on short throw shifter
- g35 5at sport shifter 101
- Transmission "Pin" that breaks
- Clutch problem
- What Fluid for Transmission and Diff??
- Leak on the rear Differential advice plz
- Gears n Pulleys - Gurus Enter Please!!
- diffrential skip??dont know help..
- $365 to install rear dif gears?
- Aftermarket Clutch benefits
- Question about the stock clutch on a 2005 sedan 6mt
- 5th gear problems....
- rear end gearing
- Jwt clutch/flywheel pedal engagement
- shifter can be pulled out of gear???
- ACT Clutch and Flywheel Problems
- Manual Transmission Lube - What weight/brand?
- Gear Ratio changing?
- Buzzing noise when shifting into reverse
- new manual tranny
- What color is your Clutch Fluid
- People with stock clutch and flywheels, check in
- Question for people driving manual G
- Possible resolve to stiff shifting
- Tranny and rear diff fluid
