- Clutch adjustment on an 05
- Diff between interval service main vs 30k tuneup?
- VLSD Fluid Change Help Please
- stiff gear switch after 6mt fluid replacement by dealer
- flywheels
- OS Giken Goodness
- What is the best short shifter for coupe?
- Nismo Clutch and Flywheel installed
- Rear Differential Oil
- 5th gear issue
- Has anyone went from 5at to 6mt
- Clutch/Tranny service ?'s- advice needed
- Rogue Short Shifter??
- AT Tranny Flush vs Drain/Refill
- clutch comparison
- How many bottles of motul rbf600 for clutch bleed
- Need help ASAP conserning AUTO transmission
- How do I know if I have the VLSD?
- Difficult to engage first & reverse gear only when car is running
- Clutch pedal vibration
- MT knocking in neutral
- Those familiar w/ 5th gear grind. I need your help!!!
- Changed rear differential fluid, SLUDGE on the megnet?
- Problem with Auto - Manual shifter
- 5AT questions
- proper break-in for clutch(jwt)
- Car just stopped getting power in 6th gear.
- Lag time between Reverse to Drive
- Checking ATF Fluid
- Orc 409 (single disc) vs. OS Giken Str (dual disc)
- Used G35 6MT '05 Sedan Clutch Issues.
- Which clutch is better?
- need help to choose a aftermarket clutch kit
- Transfer Case Oil
- Has anyone seen what their clutch master clylinder looks like?
- Question - 3.3 Open Diff to 3.7 VLSD
- A/T Transmission fluid charge pipe?
- 5AT hesitates/slips out while cruising.
- NISMO Super Coppermix Twin Plate Clutch Z33 V35 VQ35DE
- burning your clutch..
- Transmission Fluid Flush
- Transmission Hp Rating
- Clutch safety
- Urgent: Faulty clutch master cylinder?
- Resurface stock flywheel?
- 6mt drivers *clutch burn*
- Installed RE Shifter / 5/16 Spacer
- Clutch adjustment/pedal stickyness
- What PARTS to change besides CLUTCH DISK ?
- 5AT transmission controller
- Final Gear Thread.
- Clutch question...
- Manual Tranny
- G35 Manual Tranny
- 5AT question.....
- Differential drain plug hex size?
- valve bodies/torque converters HELP!
- Question for those with a 5AT.
- problem with re short shifter
- Clutch master/ slave cylinder replacement
- 2nd gear clunk, pop, grind fixed under warranty, did it work?
- stock clutch or aftermarket?
- 5th gear grinding
- 3.7 FD w/ Open Differential
- Difficulty shifting into 5th...
- HELP!! SLIP and VDC Off
- lower shift fork snapped?
- need clutch and flywheel what should i get
- Clicking From Shifter when Applying Brake
- trans 6 speed forsale
- RE short shifer--control socket
- Rear diff making noise....
- Auto tranny
- JWT Flywheel & Clutch...Installed
- Manual transmission whine when cold
- car smell after tranny fluid change
- Reverse gear doesn't work in my 5at
- Slow Clutch Return?
- Auto Trans Fluid.....
- What's a Slip Bearing(a japanese term for the clutch/flywheel)
- Syncro's bad (transmission is going to be replaced) -should they replace my clutch 2?
- SS clutch line installed
- Nismo Clutch
- 5th won't engage!
- auto diff
- diff. oil modifier
- RAS (AWAS) Question: Not sure where it belongs
- Ruh Row... clutch woes starting
- Clutch installation/ Transmission removal
- Just installed JWT clutch and fly - .5 -1.5 rpms Grinding/rattling Noise ????
- clutch install...
- radiator upgraded/tranny fluid?
- Manual Transmission HELP!
- clutch noise
- Transmission removal/ installation help!
- SPEC clutch noise?
- Automatic Transmissions
- 3.91 Gear ????
- 350Z Rear Diff
- Tranny and Diff. Fluid Questions
