- 5AT Vs. 6MT
- How many have clutch chatter off the line?
- Questions about changing clutch/flywheel or do I have a bad tranny?
- Damperless clutch = unsprung hub?
- 3.90 gears????
- Which Lightweight flywheel????
- One more clutch question.....
- Clutch Pedal 'sticking' - Throw-Out Bearing?
- (ADVICE/HELP): Gears grinding on '05 6MT Coupe!
- Rogue Short Shifter problem...
- Steel clutch line - good or bad?
- Need a clutch - ORC clutch
- tranny and differential fluids
- 6mts tranny replacement....who&where?
- Pumpkin swap
- Engine or tranny rattle/chatter problem?
- Trans. Question
- Why won't anybody answer this question?
- 6MT Grinding when reverse, letting clutch out
- rogue shifter help!!!
- Short Shifter Help
- Trany oil change/gears problem
- is my clutch slipping? =(
- Clutch Issues
- stillen or any other clutch on 05-06 g35c
- Trans flush and fill Price?
- Possible clutch/flywheel issue
- AT Triptronic
- Dealer replacing my 6mt tranny
- Rogue Engineering Short Shifter Install
- '06 Pumpkin into '03 G Coupe swap: IT FITS!!!
- Manual Transmission Swap Project!!
- lighter flywheel questions?
- Just Bought a ACT 6 puck clutch kit....
- 6mt short shifter help
- 1 Piece Driveshaft????
- Clutch Break-in?
- Automatic converted to Manual
- Clutch Question need some help guys!!!
- 3rd-->6th gear grind when shifting at high rpms
- Grinding Gears?
- Transmission whine - please help
- My clutch smells like siht
- Is it possible to break the shifter?
- Throw Out Bearing
- Additive for LSD diff?
- Driveshaft replacement
- 03 6MT Transmission replaced...and now...noise
- Short Throw DIY??
- Anyone switch the shift direction for manual mode (auto tranny)
- Aftermarket Clutch Install at Dealer? Yes or No?
- Gears!
- Clutch GONE at 38K???
- Time for a new clutch!!!
- Spec fly wheel installation issue
- Should I get this used RE shifter?
- Trassmission upgrade question.
- Clutch question.
- Help DIY for transmission
- What is your clutch/brake life?
- 5AT - What can be done FI wise?
- Valve Body? Which one?
- Anybod have a built 6 spd trans?
- New G35 Transmission-need info
- 03-04 Auto Transmission Chattering/clicking
- What tranny oil are U MT guys using?
- Tranny shutter???
- How durable is the rear diff on these cars?
- A different kind of AT shifting problem
- TH-400 Transmission Swap
- Where to buy JWT clutch??
- Stillen stage 4 plus clutch install with pics.
- Looking for LSD 03 G35 Sedan with 6MT
- 03.5 sedan tranny Software
- 6mt tranny
- Clutch Improvement Idea
- flywheel and warrenty question
- Shifting gears...
- Transmission, Rear Diff?
- Bad news: for people who has an AT with 3.53FD upgrade
- clutch/shifter
- Skip shifting w/ FI
- Help with clutch; mushy pedal
- another clutch question
- Installing shift knob
- screwed up a launch big time -fried my clutch?
- 3.53 Gears
- WARNING: JWT Flywheel needs dowel pins
- Stock g burnout?
- 06 sedan 5AT transmission 'shudders'
- Stiff as F*** clutch!
- 6-MT, Rear Diff Fluid Change
- Squeeky Clutch - need some advice
- 350Z and G35 clutch comparison?
- Level 10 5AT valve body upgrade installed
- umm.my shift lever snapped in half.suggestions? (pics)
- Does my G have an LSD?
- Clutch Problems
- Clutch squeeking when pressing
- clutch squeeking/screeching problem?
