- help 03 coupe clutch out
- Clutch pedal sticking and burning complaints come here
- Clutch issues
- Quaife LSD & 3.5 Pumpkin Install
- "Noisy" gears from OEM?
- Clutch pedal squeaky
- Clutch Rattle?
- Torque Converters: WTF???
- Clutch advise please
- Stock Clutch Position?
- Trans. ?
- Hearing sounds when i change gears...
- 03 5AT 3.53 Gear Swap.
- Valve Body/TC or 6 speed swap
- S-mode in auto?
- Grinding Gears
- shifting to neutral rough idle
- Emergency - Clutch Prob
- AT shifting problems
- 3.91 Gears on a 5AT?
- 3.917 Final Drive Question
- Blown Clutch at under 11,000 miles
- Ticking transmission after driving hard
- 3.971:1 Final Drive
- new tranny = noise and power loss
- Auto to Manual swap question...
- Help!!!Installed JWT clutch/flywheel now car won't crank!!!??!
- difference between VLSD and Open-diff
- Horsepower To Wheels
- Yes, Clutch and Flywheel questions/suggestions
- does any one know the torque specs for clutch and flywheel
- AT rebuild
- Firecracker in clutch
- Clunk into 2nd
- Need help with Clutch!
- gears not engaging after brake-torque start
- Tranny Problem
- Tranny and Diff Fluid
- Clutch Help! (for a soon to be owner)
- Is Castrol Multivehicle ATF oil safe?
- 8lb Tilton Clutch Package??EXEDY Carbon Twin Clutch??
- 5AT question?
- Carbon-Fiber Driveshaft
- weird thing happened today....
- Clutch position switch
- Shifting Gears W/ the MREV+
- Removing auto tranny valve body?
- Clutch Work - How much is reasonable?
- Anyone have experience w/ RPS Flywheel?
- Help!! Tranny disengaged!!
- Drivetrain Parasitic Loss
- Rearend for 500hp+?
- Auto shudder on 2-3 shifts.
- New Tranny!!!
- 3.9 gearing question- important
- Q: Driver-adaptive learning algorithm 5AT
- nissmo lsd differential
- What aftermarket clutch set up is everyone going with?
- Stillen VB upgrade...problem??
- clutch pedal vibration
- anyone researched 3.7 central20 gears? (5a/t or 6m/t)
- Labor Costs for Clutch Install
- Transmission problems?
- Will any of these short shifters work?
- 6mt 5at
- auto tranny dip stick
- Auto tranny manumatic question
- clutch wear?
- Transmission Problem, '04 AT, please help
- Centerforce clutch's
- clutch setup
- Rear Axle Bolts
- clicking noise (NOT AXLE) and tranny problem
- Transmission software question?
- stock 350z clutch and flywheel
- Nismo Short Shifter
- I have a 5th Gear Grind (but also aftermarket clutch/flywheel)
- 05' 6mt grind noise at 5mph after start up
- 05 6mt tranny
- Clutch Slipping @ 17k
- -----lsd-----
- Who has replaced a tranny? Please chime in with details
- Clutch pedal modification-problems?
- 6MT: Wierd vibration in clutch pedal
- No more 350evo "Monopoly" on Gears?
- New Tranny Already!
- Clutch sensor for ignition
- Throttle Position Sensors problems or something else???
- Noise Only When It Is Cold
- 3.9 Final Drive in automatic
- has anyone tried the RPS clutch or flywheel??
- Question about Shifting into Gears
- Anyone change their ATF by themselves?
- Transmission Problems????
- transmission troubles. lost 5th and 6th gears.
- 5AT Transmission Flush
- quaife lsd
- SGP Racing Engine / Tranny Packages
