- Clicking Clutch, Any idea what it could be?
- 06 G35 No Start
- Whining Noise on 06 G35 6MT
- G35 Rear End Question
- Hi gues. Hello from Georgia. I want some help please.
- Clutch
- Need help picking clutch kit!!
- 2005 G35 Coupe and Sedan transmissions
- New clutch, new problem
- 03 sedan vlsd swap
- 06 Coupe No Start U100 Code
- built trans 5AT questions?
- Recommend me a clutch for 2005 G35
- Auto Trans flush on 06 coupe?
- G35 Coupe Clutch Disengagement Issue
- Mishimoto coolant/power steering tanks
- Anyone have JWT clutch and RJM pedal?
- Intermittent sports shift issue 05 G35 sedan
- Stuck in 3rd gear
- Overdrive add-on to 5-speed auto possible?
- Clutch issues!
- Opinion on ATS twin plate carbon lutch
- '05 G35 Coupe- Transmission Fluid Question
- Valves
- approximate time to swap manual trans?
- Clutch Replacement - Need to drain trans fluid?
- 08 G35X trans engagement question
- Drivetrain questions
- 4.08 gears in a auto (final drive help!!!!!!!!)
- Front differential shot @ 138k
- ATF in radiator
- G35x transmission questions
- 07 G35 6 Speed New clutch ?
- 04 G35 Coupe 6MT noise / clicking / play
- 5AT Mode Selector Switch
- Clutch replacement question
- Need new clutch need help!!!! Pls!!!
- Slight "knock" at specific speed
- Help with rebuild!
- Clutch creaking/squeaking
- Clutch pedal woes and some questions
- Vibra-technics motor mounts?
- Differential bushings
- Transmission issue after new clutch 07 g35s sedan
- Different in G35 engine sedan vs coupe
- Max Torque stock transmission can handle?
- Solution for High Clutch? Regular Adjustments OR D-Wolf Clutch/DIY Method?
- clutch noise?
- Hard to get in gear
- 06' Coupe Shaking
- Valve replacement
- What clutch should I get?
- Clutch Replacement Options
- 05 G35 coupe transmission issues
- 03 G35 Coupe Clutch/Fly Recommendation
- 2006 g35x awd not working.
- clunky AT
- 03 G35 transmission fluid J or S?
- Recent ATF drain/refill, now car shifts extremely weird.
- How to remove bell housing bolts on trans?
- Replacement Trans arriving today. Is there DIY a write up? 2003 5AT
- 3.7 diff swap. Vdc slip light.
- Transmission replacement. Which model to I get?
- RB26 Gearbox in a G35x?
- G35 oil intervall
- Replaced clutch, lost pedal pressure
- 05 coupe auto bad tranny?
- 05 Clutch pedal stiff: dealer says new clutch kit?
- Review: ACT Clutch and Streetlite Flywheel
- 06 G35 6MT Clutch sticking (FULL rebuild)
- Play source upstream from driveshaft?!
- Manual mode downshifting in an auto, is it safe?
- Opinions on a 6MT high pitched whining noise?
- CD009 in my 2005 6MT?
- Rear end dog tracks only under heavy acceleration
- Removed transfluid for weight reduction, now it won't go into gear
- A Unique Open diff to LSD Swap on a Sedan
- Adding fluid after leak
- Will a 2015 NISSAN 370Z oem rear differential with carrier bearings fit a G35 coupe
- 04 sedan Slave Cylinder brand and stainless clutch line
- AC or alternator belt ripping?
- Transgo Shift kit
- 04 G35 Auto Transmission Problem?
- Ugly sounds
- 2003 G35 Sedan RWD Automatic question
- Throw out bearing issue
- fluid reccomendation 2003 6mt and diff
- new Problem with 2005 6MT shifting
- Crank Shaft Seal Replacement / tensioner pully bearing replacement
- A Different Kind of 'Ticking' than I have Found on Other Threads
- G35 sedan fuel pump
- VLSD Rebuild kit?
- Tomei Technical Trax PRO Kit - Limited Slip Differential
- AT5 loss of power
- Transmission interchange
- Tranny not shifting correct AT
- Humming Noise
- Clutch line pipe replacement help!!!
- Transmission Issues
- Please help!! Anyone
