View Full Version : Drivetrain
- Transgo Shift Kit??
- Clutch problem car is stranded...
- Weird Noise When Clutch is Pressed
- Unknown Issue, Possibly Tranny
- 07 Auto coupe shifting issue
- Transmission identification help
- Gonna need a new tranny..a couple questions
- Changing Clutch 2003 G35 6MT Sedan
- Issues with Clutch line install and bleeding
- Rear Differential help needed
- Need help with weird noise
- Transgo Shift Reprogramming Kit Adventure
- os giken clutch replacement
- 2005 g35 coupe clutch replacement combo
- 08 AT LSD to VLSD swap
- 350Z and G35 Transmission
- 3.3 gears to 3.70's
- Changing fluids
- Transmission Done for HELP TCM? VALVE?
- Need so Help
- Clutch = dead pedal halfway to the floor
- What's the best flywheel and clutch kit
- Manual Transmission Question
- transmissions issue can i reset it??? HELP
- Transmission problems?
- VDC, 3%, the big picture?
- 3rd Wheel Bearing 04 G35X
- Canadian VQ35DE in USDM G35
- Will Nissan Brake Solenoid Valve Work in G35x?
- Nissan MTF (manual transmission fluid) discontinued?
- Solenoid Codes in '05 - Need advice on fix
- differential swap 3.54 to 3.692
- Spongy Clutch
- Why I won't be going to this dealership for my transmission service.
- Is this a Sudden Synchros Issue?
- 04 G35 Throw Out Bearing keeps going out
- Bad Clutch Line...Fixed and now 3rd Gear Grinds?
- Unorthodox pulley set question
- ATF Fluid question
- Shut off mid drive. Lights are on now
- Video - Asymptomatic Engine Whine
- Roaring noise?! Wtf
- G coupe rear diff bushing
- Driveline clunkage
- Replacing oil pressure switch
- 6MT output shaft bearing/bushing replacement?
- Need a New Engine... What to Do...?
- 05 G35x Wheel Bearings - Need an opinion
- 06 g35 coupe 5spd auto
- Clicking / Knocking Around Sound
- Throw out bearing, hydraulics, ttransmission???? Something's failing
- 600WHP, Killed my JWT Clutch
- Whining Noise When Driving Initial 5 Miles from Start Up
- Heavy Clutch Help - Solutions to New-to-me G?
- Few questions after searching
- Transmission/Driveshaft Noise
- Master to Slave Cylinder Complete SS Clutch Line Conversion
- 2004 at diff swap
- Replacing Transfer Case 04 G35X
- Need help with Clutch Master Cylinders
- Important purchase, advice needed!
- Does anyone else have this rattle?
- Clutch or Transmisson?
- JWT Clutch Users, Need Response Fast!
- Car dies when clutch pedal is pushed down??
- Leaking Rack & Pinion (2nd replacement)
- New Clutch Recommendations
- Ngk vs. denso ?
- New Clutch Break-in question! HELP!
- competition stage 2 clutch
- Clutch sticking
- xtd clutch
- AWD AT Bellhouse vs RWD AT Bellhouse?
- xtr a good clutch?
- Will a New Clutch Fix Stubborn Shifting?
- Clutch Needs Replacing, Any Recommendations?
- Automatic Trans Problem
- Reverse gear just revs....tranny replaced
- new clutch rattling
- 5AT Coupe Acceleration
- What is this part called and where do I find it? (Clutch)
- Rouge Engineering
- Clutch Still Sticking After Master/Slave Replacement
- clutch problem?
- 05 clutch issues/suggestions on replacements
- Slave Cylinder Replacement DIY?
- Clutch Problems Please Help
- Dead engine
- Manual Transmission Compatibility?
- Phoenix - 07 6MT - Transmission, Clutch replacement
- Major clutch damage, need help
- Shifter stiff
- Loud noise and vibration from clutch pedal
- Clutch Stall
- p1815 code and u1000 code
- 5th gear problems
- Vibration on decel in gear/any speed
- 300-400 RPM slips in 6th gear acceleration, Clutch review question on exedy brand..
- Car wont go into gear
- Clutch Will Not Disengage HELP ME PLEASE !!!
