- :: Carbonetic clutch - READ ::
- Dealer Says I need a new clutch
- Transmission flush at 30k, need it again at 50k?
- Amsoil differential gear lubricant
- Will a 06 350z tranny(6mt) fit in my 03 G35 Sedan(6mt)?
- tune vs gears
- Planning to buy Coupe shortshifter for my sedan
- Clutch Munched Bad
- Carbonetics twin disc clutch????
- accidentaly shifted gears from D to P while in motion
- Clicking noise...HELP!
- Wet Shoe + Clutch Pedal
- Stupid question - flywheel/clutch combo
- Transfer fluid drain/filler plug gasket part # ?
- Reviews? Nismo SS clutch line
- Premature clutch wear-what replacement?
- Z1 Clutch have PREMATURE WEAR
- Clutch Fork Pivot Ball part number request
- Powertrain hesitates
- transmission. 5AT
- CD009 Transmission and Clutch install - pedal adjustment help
- Problem: SLIP, Parking Brake & VDC Off Lights On
- Who has upgraded their Final Drive
- My DIY transmission fluid drain & refill. Redline vs. Nissan
- clutch problem, please help
- Throw Out Bearing, Lube?
- slip
- Is this normal? Tranny
- Upgrades for 5AT
- can you change the diff fluid with ramps on the rear
- Rear end question...
- What kind of replacement clutch kit should I get?
- 2003 Sedan 5AT looking to doa 6sp Swap
- Clutch problems
- should i change my flywheel???
- wheel bearing under Power/Drivertrain??
- Clutch noise during cold start
- Clutch noise during cold start up
- drive shaft seal is leaking???????????????
- ATF, differential, transfer, coolant fluid questions...
- replacing syncros
- Matic-J
- $12.50 for nissan transmission bottle??
- Cheapest to replace clutch?
- Has anyone had their clutch replaced?
- Shifter problem or transmission?
- Please help, clutch question.
- Transmission Removal Question
- Drivetrain issue?
- What you think of this Clutch? Worth IT?
- Clutch gone?!?!
- Clutch Recommendation
- Not good! need experts advice plz
- Installing ACT HDSS clutch and Prolite Fly
- Will 350z short shifter fit my 06 sedan?
- EXEDY clutch
- What gear oil for an 04 g35 MT?
- Transgo RE5R05A-HD2 Reprogramming Kit
- Am I having a Transmission issue or is it just the COLD weather?
- Do I need a new flywheel?
- Car stuck in Drive! HELP!!!
- Messed up Clutch? Please help
- How smooth should it be?
- difference between 009 and 008 trans?
- Does the 5AT automatically downshift in manumatic mode?
- Transmission Problem..HELP
- 6th gear just started grinding??
- Short shifter ruins your XMSN!
- Chip on my clutch
- High clutch engagement
- Transmission problems??? help!!
- Clutch
- Differential Mount Bushings? Help please!
- "Clunking" Noise at take-off!
- Recommend website for Nismo Flywheel/Clutch
- Transmission oil
- Bought a 2004 G35 6MT Coupe @ Dealership and Clutch ALREADY Died!
- Leaking driveshaft section
- PLEASE HELP! 03 G-AT Problem
- motha F**k sh*t. Clutch is acting up again...need more immediate advice
- Clutch Question
- AWD maintenance costs
- AT question
- Very Weird Problem. 03 G35 auto wont accelerate in 3rd.
- HELP.. Sticky(ing) Clutch
- Has anybody installed LUK Clutch and Flywheel combo?
- Automatic into a 6MT
- Aggressive shift mod for 5AT sport
- 3...2...1... Launch
- Changing the Gear Ratio on Your Car
- what is up with rattle noise on 1st-3rd gear?
- Competition Clutch
- should i let dealer install my jim wolf clutch/flywheel?
- 2004 g35 coupe clutch problem
- which fd gears work with 03 5at?
- 6MT rear in a 5AT G35 coupe question.
- WOT Box/Launch Control
- Clutch Noise
