View Full Version : Drivetrain
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. NISMO Short-Throw Shifter PLAY
  2. AT transmission issue Please help
  3. AT to MT swap list. please help
  4. Need clutch advise...
  5. Mixing clutch fluid?
  6. Does a Hr OEM clutch and flywheel fit a DE motor?
  7. Rough noise at speed - intermittent & variable
  8. new clutch and flywheel put in today and..
  9. Differential Swap 6mt
  10. 03.0 5AT just sliped REAL bad
  11. transmission shifts hard with bass
  12. clutch/flywheel help
  13. 05 G35x autotrans prob
  14. Final Drive for 2007 5AT with sport package??
  15. can't change from D to manual shift
  16. Transmission Flush?
  17. Changed Flywheel, Now Car won't run.
  18. G35 Halfshaft the same as a 350?
  19. Strange Transmission Problem (A/T)
  20. HELP!!! Transmission problems
  21. Transgo Valve Body Upgrade DIY
  22. Rear Diff fluid question ....
  23. Do i have a VLSD?
  24. Differential Drain Plug Dilemma
  25. strange noise from tranny?
  26. Need help deciding on a new clutch...
  27. Should I change my trans fluid at 90k for the first time?
  28. Vlsd Motul gear 300
  29. Mobil 1 syn ATF ok for AWD Xfer case?
  30. Clutch or Tranny or Weather Temp?
  31. Not chatter on low rev but gear noise
  32. I NEED EVERYONES OPINION! Transmission Fluid Service.
  33. Had my Transgo shift kit installed today
  34. The skinny on "axle click"
  35. RPM's at 80 MPH
  36. Clutch Trouble
  37. 05 G35 coupe - Loud whistling noise when driving
  38. 05 g35 clutch stuck to floor
  39. 5at gotta have a SprintBooster!
  40. Tranmission noise
  41. transmission question
  42. Experiences with Exedy OEM clutch?
  43. Royal Purple Transmission Fluid
  44. Any experience with Exedy OEM clutch?
  45. What's a good clutch
  46. Top Tier Gasolines
  47. Nismo shift knobs - how do they change the feel of shifting?
  48. Confused about the stock pumkin, can some1 help me out?
  49. Hard to shift cold!
  50. 2005 A/T Sedan
  51. HELP! - dealership wants $1,000 to replace front driveshaft
  52. Is my clutch going? 05 coupe
  53. The Math-Trans Fluid Drain&Fill
  54. stricky suggestions for drivetrain section
  55. Another tranny issue thread(no i did not sleep with one)
  56. AT Trans Issue PLEASE HELP!
  57. Gears 373 410 ????
  58. Need Rogue Short Shifter Installed. Orange County
  59. Wrong coolant :\
  60. Automatic Transmission rpm stuttering when slowing down
  61. 6MT Transmission Compatability
  62. 370z LSD
  63. Two times Tiptronic wont let me change gears
  64. looking for new clutch
  65. 2005 G35 Sedan AT
  66. Transmission swap question...
  67. Help stuck on neutral
  68. rear 3rd member swap options
  69. New Gears?
  70. Question about JWT Clutch Kit
  71. 06 sedan 6mt fluids changed
  72. 5AT vs 6MT
  73. AT vs MT rant...
  74. tranny change or stall converter?
  75. 05 Auto vs 6mt
  76. REVIEW: BG Ultra-Guard and BG Synchro Shift II
  77. Clutch Problem!??? HELP
  78. What transmission oil to use
  79. Rear final drive
  80. Valve Body Upgrades / Shiftkits
  81. possible bad throw out bearing and shop mistake?
  82. Another Clutch Problem
  83. Clutch sticking in 06 G35
  84. 2006 Coupe base has 3.3 or 3.5 FD??
  85. Nissan extroid 8spd cvt transmission
  86. Yes, another "Help me diagnose this RATTLE" thread
  87. 5AT Transmission stall and Service Engine Soon light...
  88. increasing the stall RPM on 5AT
  89. Quick question need help
  90. Clutch problem?
  91. clutch pedal click when releasing pedal
  92. AT fluid change and ramps
  93. Is this the imfamous axle click?
  94. Looking to upgrade clutch and new gears. Any recommendations?
  95. 5th Gear Lockup on AT?
  96. 04 AT trans fluid change!
  97. clicking noise in the rear when i accelerate and decelerate
  98. Automatic Transmission stuttering
  99. Aftermarket clutch line question
  100. OS Giken triple-plate pain
