PDA
View Full Version : V36 Brakes, Suspension, Wheels & Tires
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20
  1. V36 AWD Coilovers Finally Available - installed!
  2. Urgent input/advice needed on e-brake-vdc-slip-cruise lights coming on!
  3. drilled slotted rotors and pads
  4. 2008 G35S 18" chrome wheels
  5. Parking Brake Light Came On
  6. Tanabe Coilovers: Sustec Pro S-0C
  7. brembo?
  8. New parts to install!!!
  9. Mini-review: Motive Power Bleeder
  10. Can this be repaired?
  11. Journey vs. Sport
  12. My specs after an alignment (Eibach drop & Rear Camber kit)... your thoughts!
  13. Can you combine a wheel+HC ring and Spacers?
  14. Fast Brake Akebono 2-piece rotors
  15. Cornering help
  16. For those with Akebono's
  17. G37S Tires
  18. Squeeky sound from front suspension
  19. Need some help - Anyone with GTSpec 6point brace
  20. DIY Brake Job
  21. G35X with premium package: double piston caliper??
  22. What Tires for 2008 g35x
  23. nexen N7000 tires good or bad?
  24. DIY Brake job on 2007 G35x?
  25. JIC coilovers....
  26. KW Rant!!
  27. need suspension help!
  28. rubbing with 20s in the rear on eibachs
  29. what tire sizes should i go with?
  30. Sport Sedan with impuls exist?
  31. My Rotors - replace or turn/resurface? (Pics)
  32. Would the 19" wheels from a 2010 maxima fit on our cars?
  33. Best Place to buy TPMS Online (sensors)?
  34. Lowered 08 G35's and Daily Driving
  35. lugnuts...for vossen rims
  36. No love for the V36 Sedan?
  37. Braking to a stop
  38. TPMS recalibration needed?
  39. any rubbing issues 20"+lowered+ loaded
  40. Wheels
  41. G37S Tires
  42. Unknown Clicking sound!!!
  43. Can someone tell me if i got sport brakes?
  44. DIY brake job
  45. Wheel spacers
  46. Akebono BBK - Notes
  47. 2006 G35 couple wheels on 2008 G35 sedan
  48. Not for my G but brake question
  49. So I want to lower my car...
  50. Do i have to pay for brake replacements?
  51. need new front brake pads
  52. time for new tires...hankook ventus v12 anyone?
  53. Will 9.5" wide wheels all around on G35X Work?
  54. "pop" sound
  55. Akebono front calipers
  56. TPMS Part Number for our Sedans?
  57. Alignment each summer/winter when running different summer/winter wheels?
  58. New Coilovers Testing
  59. $600 for GoodYear Eagle GTs - Deal or No Deal?
  60. Will the Akebono BBK fit 50 offset + 15mm. spacers? (pics with the template inside)
  61. M35/45 18" rims on a G35x 2008?
  62. New Stance
  63. G37 Akebono BBK
  64. 245/40/19 all around on G37s rims?
  65. Proper offset for 20" on sedan without BBK
  66. Question about SS Brake Lines
  67. Dropped and Uneven with S techs.
  68. Anybody have a problem removing nut on bottom of strut assembly?
  69. eibachs on a stock s
  70. Question on curbing wheels while driving
  71. Real Coilovers?
  72. Tanabe sustec under brace on X?
  73. +30mm offset on a 18x8 wheel ok?
  74. Yeah or Nay
  75. Fast Rims???
  76. K Sport Kontrol Pros
  77. Some questions re: SPC front camber arms
  78. Rotors and Pads choices
  79. Pic Request - Aftermarket 18's on a 2nd Gen Sedan
  80. Custom Koni Yellow Setup for X sedan
  81. Mechanics/Service centers in Boston
  82. Tires- suggestion
  83. Effect of tiers of different thread on and AWD transmission..
  84. GT Spec braces
  85. Which all-season tire? 19x8 245/40/19
  86. Tire Choices: Toyo, Nitto and others
  87. just installed some GTSpec braces
  88. What size tire for 18s?
  89. RS*R spring set for V36 sedan
  90. Lets discuss rims
  91. Eibach springs on 2007 G35X
  92. Wheel/Tire Sizes 2007 G35X
  93. Wheel Fitment Questions
  94. aftermarket shocks
  95. Eibach Pro Kit
  96. need brake information
  97. Akebono BBK on stock 18" rims, I need info plz
  98. What size tire & where can I buy tpms's?
  99. Rotor judder, part deux
  100. Brake light on when driving fast
