- TE 37 help with fitment and tire choice
- How wide can you go on the front wheels? - 07 G35s Sedan
- Installed G37S coupe springs on G37X!
- g35 gt spec strut bar
- Will this work?
- Two piece rotors for Akebono are in - pix
- Are the struts between the X version and RWD sedan interchangable?
- spacers needed for g37 19s on 07 g35S?
- Squeaky noise when going over a dip or bump
- GTSPEC Rear Lower and front subframe
- Tire Problem
- Ichiba spacers on 2nd Gen, what lugs do i need?
- What are the best aftermarket brakes?
- K Sport Kontrol Pro
- Braces for rear for G35x?
- camber kits - DIY install or not?
- What exhaust should I buy...
- Linea Corse Lemans Wheels
- Coilover Questions
- Coupe Shock/Springs vs. Sedan Shock/Springs
- 07G Sedan Sport Front Brake Calipers
- any tips for spring install?
- Is this how you fit Hub adapters? *Pics inside*
- WTF are these??
- Good aftermarket End-Links?
- Tire options for the G37 coupe wheels
- onlinetires
- Any recommendations for slotted rotors on the Sport model
- Coilovers Part 2
- Will these Volk wheels fit?
- Coilovers
- 19" vs 20" rims
- G37 Akebono BBK
- Camber Kit?
- 19" wheels for 07 G35 Sedan Sport
- 20x10 offset 40....
- G35x AWD sway bar sizing
- Wheel spacers, need your input.
- How much to install eibach springs on the X?
- Quick help for 07 X
- anybody heard of B & G springs.
- Anyone out there with a G35x with G37 coupe wheels?
- Quick wheel fitment question.....
- Aftermarket Rims
- F&F Coilovers Any Good?
- Will these rims fit?
- Would you buy Akebonos or wheels?
- Are these the correct part #'s for eibach for G35X
- difference between journey and sport rear sway?
- 07 sedan brake pads?
- Slip + VDC + Ebrake lights
- Coilover Problems
- nail on side of tire..what to do?
- tire size help
- Racing Brake's 2-pc rears for Akebono's
- Wheel Opinions
- WHICH TIRES?!? Please HELP!
- Problems with Cracked TPMS. Need Help.
- Please help! Need the OEM spring coil height for both G35S and G35X
- When you drop your car do you readjust headlights?
- Brakes Stuck?
- TPMS question
- FX35 wheels work for winter wheel/tire combo for 08 G35?
- Wheel fitment question 2004 Coupe Volk wheels on G37 Sedan?
- 20x9 and 20x10.5inch wheel fitment help!
- using sport suspension on X
- 225/50/18 Replace With...??
- X owners...I found a NorCal X member
- Removing rear rotors - Quick question
- quick help please
- Wheel Spacer Advice Needed
- Which spc camber kit?
- 245/50/17
- Kuhmo ecsta Platinum issue
- Can i buy just a rear aftermarket sway bar?
- Sway Bar Help
- Can I run staggered g37 rims on my 07 SEDAN?
- RU Running "Grand Touring Tires"?
- Different Wheels For Winter Tires?
- new back brakes need quick help
- Camber arms for Eibach Drop
- Tire wear...
- Can I use this to lubricate my ARBs?
- Do OEM Akebonos fit '09 G37X sedan?
- can i fit 19x9 OEM G37S wheels on the X all around?
- Tire Pressure Sensors: Car/Set Specific?
- Anybody running g37s brake kit? (14" Rotors)
- X-Post: BC Racing Coilvers for 07+ G35X/G37X owners...
- BC Racing Coilvers for 07+ G35X/G37X owners...
- Tire size advice
- Is it ok for front and rear tires to be different?
- Impul spring rates, does this make any sense?
- Engine Damper
- TPMS not functioning?
- Experts needed. On the topic of lowered cars, camber, and OEM alignment specs
- Need help buying winter tires
- for the X, would you run 19x8 all around or?
- Camber Kit Question?
- What is the point of all-season tires?
- Akebono vs Stock brake weight
