- Can G35 Sport tires be rotated?
- Tire Balance and Rotation?
- INSANE TO DROP?...24K miles/year highway...
- Journey springs vs. Sport springs
- Lowering and suspension life
- G37 Big Brake Kit - Seperating
- Another lame tire question, please give input
- H&R Springs
- Cheapest OEM Brakes
- Stock suspension Question
- 20" x 9.5" wheels on X
- H&R sway bars shipped.
- Shocks & Springs or Coilovers?
- 2007 g35x vs 2005-06 rotors
- 20" wheels in rear and 19"s in front? Anyone??
- Brake care warning
- 07 G35 Sedan Brake Pads by VIN Number????
- stupid quick question. Sport springs = non-sport springs?
- X Drops the spot
- Brake Installation
- is there anyone know can we put the Stillen sway bars front and rear on the "X"?
- For those of you with rims (TPMS)
- Ordered new tires- Sumitomo HTR Z III
- Help With New Tires
- What Are The Widest Size Tires You Can Fit On A 20x8.5 Rim... 265-35-20?? Will That F
- Lowering Springs ... What's the Difference
- eibach pro kit springs after they settle?
- Rear Sway Bar
- Question about rim size for G35x 07 - Tenzo rims
- Anyone try Nexen N3000 tires?
- Now my Front stillen sway doesnt fit?
- Let's talk springs
- My new tires initial thoughts Kumho Ecsta LX platinum
- Tire Pressures...
- Which summer tire for oem g35s wheels
- Wheel and tire size help please
- Eibach Pro-kit springs with M45 rims
- m45rims on H&R springs...can you put on spacers without rubbing?
- Brakes
- Spacers question
- Would these RAYS wheels fit my 07 G35 sedan?
- I Need OEM brake pads for G35S
- slooooow, tire pressure loss
- Tire question for 07 G Sedan Sport?
- Transmission (Is it ok to downshift to reduce wear and tear on the brakes?)
- Tire Pressure Sensor
- Will g37S wheels have fitment issue on 07 sedan
- Weird Brake Rust
- G35s Tire?
- Stillen Sways vs Stock Sways - Info and review
- Extended Studs Neede For 10mm Spacers?
- when to change brakes?
- 255/40/19 Fronts - 285/35/19 Rears
- m45 rims and tires
- Eibach camber kits?????
- Will my tire fit?
- Front Only Drop - on X.
- Wheels - OFFSET question
- Just ordered - Tanabe NF210 springs
- M45 rims....need help with size of tires to go with on the G35s
- Share your Driving Experiences here with Rims that are 19's, 20's, 21's, 22's!!!
- DROP HELP-- G's that'd been lowered! LOOK
- Sway Bars Which Way To Go?????
- Tire Size Question
- 07 G35x ---drop Help
- Tanabe GF210 Springs available for 07+
- NitroFil & Summer tires - Better Gas Milage
- Rusty looking rotors after rain and car wash
- Non-stretched tires
- M45 Rims...need spacers to put on 07+G35S?
- Brake replacement...
- H&R vs Eibach springs????
- Is It safe to Re Drill Wheels?
- Does swap to 19" require alignment without a drop?
- 2008 G35 Sedan Journey Brake Caliper Size
- 20x9 rims on G35x
- 350z springs on 07 g35x
- Gain back 1 degree of camber with slotted struts?
- anybody know about a coilover suspension
- rim/tire question
- Tire Question
- g35x lowering springs
- Which tire is the OEM Bridgestone for the Sport
- Has anyone changed thier own brakes.
- Camber kit
- rule of thumb for lowering springs same as 1st gen?
- Camber Kit Question?
- Alignment results w/o toe/camber kits or just w/ toe kit.
- front wheels
- Rear tire replacement time
- FYI Eibach/SPC Camber kit Unknown to work with 07/08 AWD
- Any springs work with the 07/08 awd......
- Can I fit a 275mm tire on a 9" G37 rear wheel?
- GT-R wheels!
- Can you vote on one of these three tires.
- Eibach Drop/Alignment Tire Wear issues??
- Brake Pads
- Sport Tire Size
- offset on the stock 18" g35s wheels???
- Can I mix and match the springs?
