PDA
View Full Version : V36 Brakes, Suspension, Wheels & Tires
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Tien S-Tech springs
  2. Need alignment...can I trust a chain like NTB?
  3. Question about 20 '' wheels and proper tire fitting..
  4. 2007 G35S Sedan - New Pads & Rotors
  5. help please front coilovers 08 g35x
  6. 370z rear sway bar on g35x
  7. 08 g35x 350z springs
  8. Akebono BBK install clarifcation
  9. Tein S-Tech "Saggy" for G35x
  10. Coilover question?
  11. G37S Sedan Wheel Clearance
  12. Dealing with judder
  13. HELP: SPC arms contacting fender, Lets see your solutions?
  14. Help with wheel and tire sizing
  15. Burning smell and major heat on one rotor
  16. Rust on calipers
  17. Akebono swap from an FX
  18. Suspension knocking
  19. Offset Help for 20"
  20. Stopech Slotted/Vented Rotors and Pads
  21. AMR Coilovers available for awd!
  22. VDC & SLIP are on, I've read many threads... What compound are the OE brake pads?
  23. 20" wheels offset on sedans question!!
  24. Hawk HPS or StopTech Street Performance Pads?
  25. Tokico Blues
  26. R1 Premium Rotors and Rust/Corrosion
  27. Staggered Wheel Configuration for AWD?
  28. KNS Brakes - One Stop Brake Shop
  29. 4 'fronts' for all-seasons, 4 'rears' for summer tires
  30. will these fit?
  31. I think I didn't intall my rotors properly
  32. 235/35 and 245/35 on g35x
  33. Winter wheel setup
  34. 20x10.5 all around anybody?
  35. Michelin Pilot Supersports - how long should they last?
  36. G37 2012 IPL suspension on v36 sedan?
  37. 350Z Nismo S Tune Springs on 07 G35x??
  38. SPC rear camber arm and toe bolt question
  39. FIGS Engineering Lower Control Arm Camber Adjustment Interest
  40. does anyone know if Z33 coilovers fit on the 2nd sedans?
  41. shopping for a suspension upgrade
  42. Lowering and tire/wheel setup help
  43. To DIY or not to DIY - swap out rotors/pads/brake fluid
  44. Spring+Struts or Coilovers?
  45. Power steering stiff when warm! 08 XS
  46. New rotors and brake pads recommendations
  47. SPC front camber kit: version 3?
  48. Can I put a spacer under top strut mount?
  49. Brake question for xS sedan
  50. anyone here have a TPS programmer?
  51. Figuring offsets
  52. Installed aftermarket wheels, TPMS light did not turn on?
  53. TPMS question
  54. 20x8.5+20??
  55. Another brake pad thread
  56. Is this the best Akebono BBK deal?
  57. Power Steering Woes
  58. Rotor question
  59. My Rebuilt Powder Coated Brakes, SS Lines, and Rotors
  60. C&D / Tire Rack Summer Tire Review for 2012
  61. Wheel fitment on stock height
  62. Rota Torque or OZ Ultraleggera offsets
  63. KONI struts/shocks for my Eibach springs!
  64. #2 Did my Akebono BBK install! The process and MORE issues!
  65. New Concept One CS 5.0 on G35x!!!!
  66. Did my Akebono BBK install today! pics inside of the process and issues!
  67. Spongy - Soft brake pedal feel - help
  68. Eibach PK installed - initial impression
  69. sticking driver side caliper,,, rear
  70. Clicking noise that can be felt through brake pedal
  71. G35X: Hotchkis sway bars installed... first impressions
  72. Brake pad suggestions for X sedans
  73. Need Quick info on Dropping g35X
  74. Possible issue with fitament on fronts with 18x9.5 et35
  75. G35X: BC Racing BR CO dampers any good? And other questions.
  76. New Kinetix Front Camber Arm Noises!! Any clues?
  77. A few different questions
  78. feedback on all four corners rotor and new pads install
  79. 20 inch MRRs with H&R spings. Too low?
  80. Thoughts on these 350Z 18" Rays
  81. Thoughts on this brake setup (R1)
  82. Finally got some new kicks for the ride.
  83. Rank these upgrade options
  84. 370 big break upgrade
  85. Spacers for 20x8.5 +42
  86. 350z tanable springs will work on an 08 sadan, correct.
  87. D2 RS Coilovers
  88. 08 G35x sport Eibach pro kit
  89. Should i buy these coilovers ?
  90. Brakes not fully disengaging?
  91. 350z h techs on 07g35x?
  92. What size spacer's for 20x8.5 +32 offset?
  93. Tire problems?
  94. tire size 20x9+35 w/spacer 20x10+25
  95. BC BR Coilover Rear adjustment! Need help!
  96. [REVIEW] = M7 Japan Coilovers for v36 =
  97. G35 coupe rear camber kit on V36 sedan?
  98. Looking for new shocks
  99. Wheel locks
  100. Advice needed
