PDA
View Full Version : V36 Brakes, Suspension, Wheels & Tires
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20
  1. sway bars
  2. why are the tires so bald
  3. Will 08 G35S S Sedan Wheels clear the bbk
  4. Wheel Pic Request
  5. Opinions on wheels
  6. Cheapest place to purchace Nankang NS2 tires??
  7. Rear Brake Pads Shim Kit
  8. Can you replace standard brakes with OEM Sport brakes on a '07 G35x?
  9. New 18" VS-XX
  10. coilover install
  11. Power Stop Evolution ceramic brake pads?
  12. 4x4 SUV winter tires on G35x
  13. coilover decision today?
  14. Pics of my new wheels
  15. Question on tire sizes for 19" rims
  16. Spacers?
  17. Got something new
  18. Another Offset Question
  19. Wheel question...
  20. myg37 plastidip rims.. someone finally did it! aha
  21. ABS, VDC, SLIP lights on after rotor/brake install
  22. OEM 18" and 19" sports wheel weight
  23. Staggered Wheels
  24. Has anybody used RWD struts on AWD?
  25. 20x10 +37 285/30R20 ???
  26. 08 G35s Brake Judder
  27. braking
  28. do anyone else have bottoming out problems
  29. BBK question
  30. 19x11
  31. tires for 07 g35s
  32. Effect of 19" wheels
  33. Opinions on this wheel/tire setup?
  34. Stabilizer connecting rod popped out! Help!
  35. 2007 g35x wheels w/ tires where to sell them?
  36. Bridgestone Potenza 960 AS
  37. What's up with the different mfg offsets
  38. Offset question
  39. Color Wheels for Black Sedan?
  40. G35 with tein springs
  41. 07-08 OEM G35 Sport spring rates?
  42. Changing to larger wheels
  43. Any OEM replacement caliper offerings
  44. new kumho shoes installed
  45. 07 G35S rotor size
  46. Lugs for Work Varianza T1S
  47. tire size question/suggestions
  48. Staggered set up on my 'x' is it an issue?
  49. Need help on brakes!!!
  50. Will these rims and tires fit?
  51. Coil Over Installation Price
  52. new eibach springs for the g35x?
  53. Wheel Gurus - Please help! Offsets
  54. 07-09 Brake Judder TSB fix
  55. Opinion on Tires
  56. Best Option
  57. Non-Staggered Tires? HELP
  58. Miro Type 111 Wheels on G35
  59. rear brake pad help plz, asap!!!!!!
  60. Continental ExtremeContact DWS
  61. REO960a pole psoition tires
  62. 08 g35 sedan Hotchkis sway bars on 11 g37 sedan
  63. Loud Rattle from JIC Coils
  64. Is 245/45R18 tires ok to use on 07 G35x?
  65. Is Running?
  66. I need help with wheels
  67. suspension question for x model
  68. DIY Brake Judder TSB today
  69. Need PN for RSB from S RWD
  70. 20" vs 19" G35S RWD
  71. Wheel and Tire Help
  72. Looking for a Spring for 07 g35
  73. Quick 'n Easy Strut Extender extenders
  74. Best aftermarket springs to use with stock sport struts?
  75. solution to poor tire availability on S
  76. Need spring help. '08 S sedan tein-H or H&R?
  77. where to get lowered car aligned in orlando?
  78. Wheel Set-Up Assistance
  79. Question on brake pad life
  80. need help with tires for g37 19s....
  81. TPMS swap
  82. Lowered X droopy bum syndrome; swaybar related?
  83. Intermitten vibration in wheel and pedal at 75-80
  84. Wheel sizes and offsets question
  85. Tighten E-Brake
  86. Tires and road noise
  87. Sport Sedan rear brake size
  88. A/S Tires Recommendation
  89. Replaced front shock absorbers on G35x
  90. 07 Sport Tires
  91. HeLp...staggered wheels for G35X will it affect my VDC?
  92. Q about Retrofitting Akebono's onto g37x....
  93. weird noises after spring install! help!
  94. are michelin tires finally available for g35s?
  95. Brake Judder
  96. I need sways badly !!!! the Coil aint enough~~~
  97. Tire Decision Help - All Season Tires for the G35x
  98. have anyone tried/used this camber kit
  99. For everyone running Hardcore Neg Camber
  100. 2007 G35X need winter tires?
