View Full Version : V36 Brakes, Suspension, Wheels & Tires
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. defective Nitto tires?
  2. Tein-H-Techs
  3. Tien-Stechs
  4. G37 sedan coils fit a G35 sedan?
  5. G37 sedan coils fit a G35 sedan
  6. 2008 g35x lowering springs
  7. Need Help!!! Pinging, Knocking after installing HSD coilovers on V36 Sedan
  8. Tire Wear Questions
  9. 19x8.5 +30 front/ 19x10 +38 rear..need proper tires!!!
  10. Tien S-Tech springs
  11. Need alignment...can I trust a chain like NTB?
  12. Question about 20 '' wheels and proper tire fitting..
  13. 2007 G35S Sedan - New Pads & Rotors
  14. help please front coilovers 08 g35x
  15. 370z rear sway bar on g35x
  16. 08 g35x 350z springs
  17. Akebono BBK install clarifcation
  18. Tein S-Tech "Saggy" for G35x
  19. Coilover question?
  20. G37S Sedan Wheel Clearance
  21. Dealing with judder
  22. HELP: SPC arms contacting fender, Lets see your solutions?
  23. Help with wheel and tire sizing
  24. Burning smell and major heat on one rotor
  25. Rust on calipers
  26. Akebono swap from an FX
  27. Suspension knocking
  28. Offset Help for 20"
  29. Stopech Slotted/Vented Rotors and Pads
  30. AMR Coilovers available for awd!
  31. VDC & SLIP are on, I've read many threads... What compound are the OE brake pads?
  32. 20" wheels offset on sedans question!!
  33. Hawk HPS or StopTech Street Performance Pads?
  34. Tokico Blues
  35. R1 Premium Rotors and Rust/Corrosion
  36. Staggered Wheel Configuration for AWD?
  37. KNS Brakes - One Stop Brake Shop
  38. 4 'fronts' for all-seasons, 4 'rears' for summer tires
  39. will these fit?
  40. I think I didn't intall my rotors properly
  41. 235/35 and 245/35 on g35x
  42. Winter wheel setup
  43. 20x10.5 all around anybody?
  44. Michelin Pilot Supersports - how long should they last?
  45. G37 2012 IPL suspension on v36 sedan?
  46. 350Z Nismo S Tune Springs on 07 G35x??
  47. SPC rear camber arm and toe bolt question
  48. FIGS Engineering Lower Control Arm Camber Adjustment Interest
  49. does anyone know if Z33 coilovers fit on the 2nd sedans?
  50. shopping for a suspension upgrade
  51. Lowering and tire/wheel setup help
  52. To DIY or not to DIY - swap out rotors/pads/brake fluid
  53. Spring+Struts or Coilovers?
  54. Power steering stiff when warm! 08 XS
  55. New rotors and brake pads recommendations
  56. SPC front camber kit: version 3?
  57. Can I put a spacer under top strut mount?
  58. Brake question for xS sedan
  59. anyone here have a TPS programmer?
  60. Figuring offsets
  61. Installed aftermarket wheels, TPMS light did not turn on?
  62. TPMS question
  63. 20x8.5+20??
  64. Another brake pad thread
  65. Is this the best Akebono BBK deal?
  66. Power Steering Woes
  67. Rotor question
  68. My Rebuilt Powder Coated Brakes, SS Lines, and Rotors
  69. C&D / Tire Rack Summer Tire Review for 2012
  70. Wheel fitment on stock height
  71. Rota Torque or OZ Ultraleggera offsets
  72. KONI struts/shocks for my Eibach springs!
  73. #2 Did my Akebono BBK install! The process and MORE issues!
  74. New Concept One CS 5.0 on G35x!!!!
  75. Did my Akebono BBK install today! pics inside of the process and issues!
  76. Spongy - Soft brake pedal feel - help
  77. Eibach PK installed - initial impression
  78. sticking driver side caliper,,, rear
  79. Clicking noise that can be felt through brake pedal
  80. G35X: Hotchkis sway bars installed... first impressions
  81. Brake pad suggestions for X sedans
  82. Need Quick info on Dropping g35X
  83. Possible issue with fitament on fronts with 18x9.5 et35
  84. G35X: BC Racing BR CO dampers any good? And other questions.
  85. New Kinetix Front Camber Arm Noises!! Any clues?
  86. A few different questions
  87. feedback on all four corners rotor and new pads install
  88. 20 inch MRRs with H&R spings. Too low?
  89. Thoughts on these 350Z 18" Rays
  90. Thoughts on this brake setup (R1)
  91. Finally got some new kicks for the ride.
  92. Rank these upgrade options
  93. 370 big break upgrade
  94. Spacers for 20x8.5 +42
  95. 350z tanable springs will work on an 08 sadan, correct.
  96. D2 RS Coilovers
  97. 08 G35x sport Eibach pro kit
  98. Should i buy these coilovers ?
  99. Brakes not fully disengaging?
  100. 350z h techs on 07g35x?
