View Full Version : V36 General Tech Questions
Pages : [1] 2 3 4 5 6 7 8 9 10 11
  1. engine oil
  2. G37X sedan height
  3. wheel hp vs engine hp
  4. Question about idiot lights
  5. harnest like wire underneath car? anyone have knowledge on this?
  6. 2008 G35 Navigation System
  7. Washer Nozzle Adjustment?
  8. How to reset the Lock button with 1 honk?
  9. Gear Grind with Paddle Shifter
  10. Will the warrenty cover noisy windows?
  11. Seat Memory Failed
  12. Super Senesitive Car Alarm
  13. Noise when driving...
  14. dash displays service engine soon
  15. torque down wheel spacers? help please..
  16. car starts when cold but not when hot
  17. Exhaust Problem after Lowering G
  18. Maintenance required battery...
  19. low rpm, low mph surging / bucking
  20. keyless entry system button not working
  21. SES light. what to do!?
  22. GTSpec Strut Bar or Intakes?
  23. keys locked in my G
  24. Question about cabin filter
  25. Key fob reprogram issue. Need help!
  26. Clicking sound coming from right wheel well
  27. I have a couple of questions about the new G
  28. Anyone try Royal Purple Synthetic Blend Oils?
  29. How to fix passenger seat?
  30. Battery Acid? Help!
  31. Over ride front driver's seat from moving back
  32. G35 Sedan aftermarket
  33. incabin air filter question
  34. How do YOU make your G35 Sedan faster?
  35. Trac and Slip light on dash sometimes when i start car
  36. Which first.........
  37. Couldn't they make it a bit easier.....
  38. Castrol 5W30 over achieves.
  39. a window problem
  40. 2007 G35X Wiper Blade Part Number
  41. Two Issues
  42. OBD location
  43. modding my g35, need some suggestions
  44. Airbag light flashing
  45. Belt Ticking and Low Tone Noise...?
  46. Infrared thermometer + Driving = Fun
  47. Oil Change Interval
  48. need thread size
  49. Rear License Plate Lights not working
  50. MicronAir In-Cabin Air Filter
  51. Passenger Side Airbag Turns Off Whenever My Girlfriend Rides In The Car
  52. What do you guys think?
  53. draining battery ploblem
  54. Car got broken into... Need some info
  55. Where can i tap for ignition?
  56. A couple of how-to's
  57. Who Uses Synthetic Oil in their G ??
  58. Re-setting
  59. Two G Drivers needed (RPi)
  60. noob question, how to remove windshield wiper blade?
  61. Car barely drivable, no power, barely moves
  62. Tread Wear - Bridgestone
  63. SES Light
  64. steering column "knock"
  65. need to know: 2008 Journey w/o BOSE Sound system, is it AMPED?
  66. Running a switch
  67. How do I open the the plastic snap on the side to run wire
  68. Question on mods for 08 X Sedan
  69. Incoming call log...
  70. Intelligent Key Low Battery Warning
  71. shift park HELP
  72. Looks Vs Handling
  73. Factory Display Size?
  74. Terry, come here and have a talk with us.
  75. fuse
  76. "VDC Off Light" and "SLIP" warning light.
  77. Torque #'s anyone?
  78. Changed battery on Ikey and it no longer works..
  79. Dials sticking in cold weather
  80. 07 g35x sedan
  81. vdc and slip light on?
  82. Towing a trailer with the 08' G35x
  83. Just keeps getting worse..:(
  84. Next Mod..
  85. strange issue when filling up
  86. What is the metal mesh thing? Can i just cut it off?
  87. OEM Air filters & in-cabin filters
  88. Reset Back windows??
  89. NYC Wheather make me do this!!!!! Black out HD light!
  90. New Mods
  91. Auto Up feature for driver side window
  92. Integrated Blackberry storm pics
  93. Window auto up not working
  94. No colour in the main screen on DVD
  95. Intelligent Key- Low Battery Light wont go off
  96. ground loop isolator
  97. Caller ID & LG Env2
  98. voice commands not working sometimes
  99. What is the Wheel HP of our cars?
  100. VCU and slip light comes on
