Thread Tools | Search this Thread | Rate Thread | Display Modes |
Best mod for N/A ?
Hi guys , i didn't know where to post...
So if this is the wrong forum pls MODS move it =) Ok mostly who ever mods their G they go for FI. But practically money is a issue for me. I just want some tips from you guys that run Modded N/A. I just started with AEM SRI, Grounding Kit. My next step is a MD Spacer 5/16". Then Exhaust system? I've read in a thread that larger tubes for intake is bad for N/A and good for F/I. I was just curious about for exhausts. What is the best mod for N/A? Thinking about performance and deep sound. Headers? test pipes ? Y pipe? catback? Btw, I own a 04 G35 Sedan 5AT. Thanks guys, Please MOD's if this thread is duplicated please remove and put a link for the old thread =) couldn't find by myself . ![]()
__________________
04.BLK.SDN.5AT Premium Pkg+ Navi(SOLD) Last edited by KorZillian_G'Sedan : 08-15-2008 at 02:15 PM. |
Get the spacer next, best bang for the buck. You will feel the difference in power.
Headers don't get you much more horsepower and cost a lot to get installed. Suggest getting an 05/06 sedan mid-pipe or a coupe mid-pipe and high flow cats with the stock system. I have read that the stock exhaust is designed well for our car and the cats are the most restrictive part. However, if you want aftermarket exhaust, look at Stillen or Borla.
__________________
'06 Twilight Blue G35 Sedan 5AT: 3M Paint Protection, 35%Tint,Clear Corners, Z-Tube, Stillen CAI, MD 5/16 Iso spacer, 350Z Springs/Front, Coupe Springs/rear, SPL Front Camber Kit, Stillen Rear Camber Kit, Stillen Swaybars, Richie STB, UR Pulleys Last edited by jimmykce1 : 08-15-2008 at 07:47 PM. |
Quote:
Im planning to go either HKS or Blitz Nur spec.
__________________
04.BLK.SDN.5AT Premium Pkg+ Navi(SOLD) |
Quote:
The HKS axle back?? A lot of people like that muffler because it looks stock, but sounds great.
__________________
'06 Twilight Blue G35 Sedan 5AT: 3M Paint Protection, 35%Tint,Clear Corners, Z-Tube, Stillen CAI, MD 5/16 Iso spacer, 350Z Springs/Front, Coupe Springs/rear, SPL Front Camber Kit, Stillen Rear Camber Kit, Stillen Swaybars, Richie STB, UR Pulleys |
Quote:
HKS SPORT EXHAUST 'REAR SECTION' INFINITI G35 SEDAN. $370 brand new on the ebay. or Blitz Nur Spec $389 or Top speed 250 TI .. im confused =p
__________________
Get the HKS I know a lot of people with sedan on this forum use it and like it. It will not give you more HP, but it sounds good.
Look at the exhaust compilation post. It also has sound clips.
__________________
Best Mod for NA?
MotordyneEngineering everything. Intake MREV lower collector Spacer Exhaust Enjoy! |
Quote:
Yea, i got an intake ...imma get spacer... unfortunately i got a non-revup =( so the MREV2 is not for me =( so basically intake, spacer, exhaust,grounding kit, TUNE ?
__________________
Quote:
Long answer: -Wrap your intake with heat wrap. -"heat coat" the upper and lower plenum spacer. -You can still get an MREV2--it will help. From the motordyne website: "When used with on the non-REVUP engine, the gains are very similar to that of the 5/16" spacer but the MREV 2 Manifold will show a slightly lower peak value, with a slightly higher average value and a slightly higher TQ value. Overall, MREV 2 Manifold provides "area under the curve" and is the highest gain plenum mod available." -Headers have minimal effect on this engine. -Hi-flow cats/test pipes may help. (I'm researching these now.) -A proper flowing and light weight exhaust will make more power and not add to the weight of the car. (I have a borla and am going to ditch it for the motordyne one as soon as I can.) -"Tune". . .get a Technosquare full reflash and call it a day. (Or get an uprev Osirus. . .) Do you want to do tune it yourself? -Grounding kits do NOTHING for power. . .but may help in transmission operation. (Only worth it if you have a 5AT). For all the heat shielding stuff listed above, you're NOT adding any power. You're preventing the engine from pulling timing due to excessive IATs (and/or heated MAF) and reducing power further. ![]() |
a Z-tube with a K&N filter or JWT Popcharger is good and cheap and just like the spacer you can do it yourself...you can do it before or after the spacer.
__________________
04 DG 6MT - Brembos, Ray's OEM 19s, Z-Tube w/ K&N, MD 5/16 Plenum Spacer, Clear Corners, Black Grille, RHBC |
Quote:
right know im using a AEM CAI ..but i converted to SRI ... I just have it because my brother gave it to me ... the sound-wise ? better then any other intake .. even louder than my brothers coupe with topzero power chamber intake .. but performance wise .,.i dont know im gonna put z tube + pop charger after ...
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
