Rev-Up airbox on a VQ35DE - special note
#61
can you tell me where to get just the back half?... after I posted last, I called Riverside Infiniti and they say it comes entire air box only... I was considered going to a salvage yard to take off just the velocity stack only.
which brings up another question - everything else about the box is the same dimensions as non-revup box right?
#63
http://www.trademotion.com/partlocat...layCatalogid=0
I thought you were dead set on aftermarket intakes working for cars assuming they had the correct tuning I'm just busting your chops.
#65
Until I use both, I won’t know which one I will run... I know I probably wouldn’t run the 04 OEM I have - however, I planned to paint it too and measure the temps with it just to see.
#66
I'm wondering if the piece of the box with the velocity ring (or even just the ring itself) will mate up with the remainder of the 03-05 box... and if so, can it be purchased separately.
I've stated it several times... I know some of you understand what I'm saying, but apparently others do not.
#69
*For those that run Stillen - with OEM exhaust manifolds or after market headers that do not cause excessive heat, I believe the difference is negligible. I'm using Crawford and they are creating far more heat than I’m willing to ignore - that’s the only reason I'm interested in the difference between Stillen and OEM heat control - once I have the OEM that I would consider using, I'll do comparison of intake temps between the two.
#71
I've already talked with Riverside Infiniti - they say its sold as entire box only, not just the half with the velocity ring... the part number that has been listed in this thread (more than once) comes up as the entire box.
what you dont get its is, i bought the back part of the air box from riverside infiniti, thats how i know you can buy it from them. I then sold it to a member here (hope he got it already). other member have also purchased the back half of the airbox from other sites also. So i know what i am talking about. I spoke over the phone with the vendor here when i made the purchase so he should know more info about buying from riverside infiniti.
#72
http://www.trademotion.com/partlocat...gOEM&siteid=55 part number---16526-AC700
or try this one
http://www.trademotion.com/shoppingc...howheader=true
here i found it for everyone
or try this one
